Zenith 6G001Y - starting
Yesterday did full recap/restuff. Forgot to take a picture, but since no resistors were changed and the only modern cap (XY rated) is black, small and is not noticeable, the underbelly looks practically original. Even the cord, old molded type.
Aligned it, IF was really off....not sure if I aligned it back then or just got it playing and put away.
Plays surprisingly well, even from AC.
Ordered the batteries for 4 radios, two 909 and two 985. One 909 will go in this one.
Next one up probably is going to be the 5G500.
Good looking radio, but in need of a new handle. Bought it for $40 in Kutztown at least 3 years ago....maybe 4....
WHAT THE!!!!!!!!!!!!!!!!!!!!!!!!!!
im reading this and find out its an old post....
i read your last post and im like,, huh? ,, keeping the old caps.... im thinking wow this does not sound like something this guy would do,,, then you reveal its a seven year old post.
im kinda laughing actually,,
i tend to pay a lot of attention to your work and a few others because there's always something to learn.
Believe it or not but the radio was working just fine, the main reason I put it back on the bench was the cord. Again, the only really critical cap here is the electrolytic twistlock which I did restuff. The rest is not likely to wreak havoc, and the values are not that critical, the leakage being really important only in C16.
Plus the radio eventually didn't inspire me then.
But eventually....I did the right thing Icon_smile
Today I received the batteries and put them in the radio. It works.
Warning: the power cord from the Surplus Center which seemed perfectly fine has the plug that is still too large for the back door to fully close. I guess the original is even smaller.
Yeah, looks really dense. It is amazing how many sets of brand A were made by Brand B. I have Mid 50s RCA that is an e...MrFixr55 — 10:15 PM
Philco 60 Power Trans
I am not 100% sure of the reason, likely due to the depth of the winding, but on HV windings of a power transformer and ...MrFixr55 — 10:04 PM
46-1213 Schematic Question
Hi Larry, Great idea on the fuse!  Place in the line at the power switch.  Best between the cord and switch.  While ...MrFixr55 — 09:59 PM
Philco 47-205
Just picked up the second of the three Leatherette Philco's. (My second one in the three-radio series) Nice shape, all p...slford310 — 09:18 PM
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
