hey guys
before gets too ugly here
we all have opinions to who we like, some are better then others, we try different people if not better then we stick with who we are satisfied with. Service and Delivery..
back to original question was if 7b7 was same as 7r7 as they look same and some one put them in radio which was cover in dust ,I recapped and replaced some wires turned on all tubes lite but that one and had no sound and being new I didn`t know
sam8)
It isn't going to get ugly, I won't let it...remember, I own the joint. Icon_smile
Eric - didn't mean to be argumentative, and as Sam said, it all boils down to which vendor you prefer. My point is that a lot of guys in the hobby who supply parts and services have other things going on and can not always provide instant service.
Oh, by the way, Marty - yes, Jim Cross is one of the good guys. Icon_thumbup
Are we definitely speaking of the same Bob?
My experiences have been excellent with him.
RE: tube substitution, there is a time and a place for it. Personally, I recommend them (Guides) if for nothing else than expanding one's knowledge.
And while there are definitely cases where the substitution of a tube can introduce different parameters, there are (my opinion) just as many in which the tube will function in an acceptable manner.
Many subs are not "either, or." Example: you can use a 5R4 in place of a 5Y3, BUT you cannot use a 5Y3 in place of a 5R4. Not that I would waste a 5R4 where a 5Y3 belongs, BUT if I was out of 5Y3s and had a 5R4 sitting in the stash, I would certainly use it until another 5Y3 came along.
In some radios the Manufacturer listed different types of tubes that could be used. Example: The Truetone D-697 on the schematic lists either a 6U7G or 6K7 tube for the RF and IF amp tubes. Another WG set does the same for the rectifier (5Z4 or 5Y3).
+1 TA Icon_thumbup
Eric
The Villages, FL
I've subbed out tubes a couple of times in the past. It kept me going until the correct tube arrived in the mail. Otherwise, the project would just sit there gathering dust. Tube sub guides are handy if you don't have a gigantic tube stash.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
There are currently 1004 online users. [Complete List]
» 3 Member(s) | 1001 Guest(s)
