Philco model 511
#31
Hi Ron,
I almost have the radio all figured out but I need the wiring color code that show what wires go to in the wire harness from the transformer to the rest of the set and also I got a lot of data from Mr Schwark but it is not enough. Also there is a production change on the big bar resistor.
It shows six taps rather than the eight and if you can help me out what to replace that resistor assembly with the correct one that would be great.
Anyway thank you for your time.
Sincerely,
Robert
#32
Personally, I would go with Heyboer. Did that for a needed power transformer on a MidWest Radio. Very large xformer. Under $100 for a custom made (not including shipping). Buying a used is well, buying a 70+ year old xformer. Yes, took a couple of weeks but looks exactly right and works great. Nice part is you can specify your input voltage on the new xformer.
Jerry
#33
I can't give you a color code for the original wires because one does not appear to exist. It is not mentioned in Service Bulletin 5 (which covers the 511 Series), nor in the long form service manual for these sets, the Philco Radio Manual of Useful Information.
It appears that a majority of the 511 Series sets were made with the six-terminal resistor, and a separate 70K resistor mounted on the end of the chassis. With this setup, think of the terminals of the multi-section resistor as having terminals 1, 2, 3, 6, 7 and 8 with no connection between terminals 3 and 6. Terminals 4 and 5 make up the separate 70K resistor.
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
There are currently 556 online users. [Complete List]
» 1 Member(s) | 555 Guest(s)
