  • 1 Vote(s) - 2 Average
Philco 116B chassis restoration
#46
I finished putting this 116B back together but it really does pay to look at the photos rather than doing the dial mech from memory....I had more knobs than places to put them when I got to this point...  Icon_redface
[Image: https://www.dropbox.com/s/zg4qmed7xu5ba8....jpg?raw=1]
OK, got that sorted out and when I fired it up the first time I was getting a good strong AM station.   I am always amazed when they work after doing all the cap replacements and in this case some surgery on the shadow meter.  I still need to clean up the chassis more and do an alignment, perhaps readjust the dial indicator mask to better match the dial scale, and continue to look for a fully functional output transformer but knowing it is working makes all the difference in moving forward and grinding through the cabinet stripping.
[Image: https://www.dropbox.com/s/6t5617auzw2dkx....jpg?raw=1]
#47
Bob, one of the things I noticed on mine is the tendency for the shadow graph mounting bracket to get bent so that the meter points slightly upward. It does not appear that yours is that way, but I thought that I would mention it.
Thanks Russ, I will check for that but I think it is OK.
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 2208 online users. [Complete List]
» 1 Member(s) | 2207 Guest(s)
