Zenith 6-D-2615 project
I started this winter's project today.  The cabinet is in decent shape with the obvious veneer chip the biggest flaw.  The plastic dial cover seems OK.  Knobs are not perfect but these were made from a material that degraded over time.  I'll probably just keep these though.  The pushbuttons are in good shape although their escutcheons have a little tarnish and rust on them.  The back is missing and the veneer on the top has a small separation at the very top that will take some careful work to get some glue under it for repair without pulling it off completely.  It does have that pesky asbestos sheet on the bottom of the cabinet that has some wear and fraying.  I've carefully put that aside but am debating whether to put it back or not.  Any thoughts? If I do put it back I'll probably spray it with clear coat  krylon to help keep further fraying down.  The grill cloth is also in relatively good shape and with some care I think I can get it back into the radio for reuse after the cabinet is refinished.
[Image: https://www.dropbox.com/s/ikxf2eqiiofdiv....jpg?raw=1]
[Image: https://www.dropbox.com/s/frgheimwdue5v3....jpg?raw=1]
[Image: https://www.dropbox.com/s/skavqbvfcvsd7m....jpg?raw=1]
I think someone has restrung the dial.  It looks to me like simple cotton string rather than the usual dial cord and they have it rubbing on a frame part that it should have bypassed.  That's going to be a PITA to string but that cotton stuff just isn't going to last too long.
[Image: https://www.dropbox.com/s/i2hetceqnxpjoh....jpg?raw=1]
I'll have to make the "ZENITH CONSOL-TONE" decal as I have not found it anywhere online.  That will be a new task for me but I see you can buy water slide decal paper for inkjet printers.
[Image: https://www.dropbox.com/s/rbp2uc5lcg4mq8....jpg?raw=1]
More next time...
It looks nice. Keep me informed: I might try getting one.
Rick Ethridge
It will be a fine sounding set when done. I would remove the asbestos, save someone else the trouble later. You can spray it with a water mist and remove with a putty knife. Dispose at the the recycling ceter hazard day or the like. Wrap in a large bag when you get it out. With new caps it will serve no purpose and freaks many out.
I have removed a few of these as RCA seemed to use that stuff a lot. Try to get it in one piece.
My humble opinion.
Best of luck.
Oh, the sheet of asbestos came out easily, just a couple of staples. I think you are right though, better to dispose of it.
Dang...those Zenith guys used a lot of caps....
[Image: https://www.dropbox.com/s/0t41gyapnhr128....jpg?raw=1]
Zenith also seemed to do a lot of twisting wire leads together and soldering them in mid-air unless someone else has been in the chassis (I don't believe so).  There are some dogbone resistors and some carbon composition.  I've seen this in some other 6-D-2615 restoration docs, probably using the last of those dogbones up during the war.
The dial cover has some yellowing but is in otherwise decent shape.  Here it is in the middle of the Novus polishing.
[Image: https://www.dropbox.com/s/d3nyx0bs0iviqp....jpg?raw=1]
  With regard to the asbestos sheet and it's removal, in some radios you may have to come up with some shims or some sort of substitute for the thickness of the asbestos sheet as items like pushbuttons will scrap along the bottom edge of the escutcheon that surrounds them. I removed a torn up sheet asbestos from under a Canadian G.E H-86 chassis and didn't even think of this until I replaced the pushbuttons and noticed that they scraped the bottom edge of each square hole in the bronze dial escutcheon whereas they didn't before I removed the asbestos.
I haven't noted whether the pushbutton assembly in this set is suspended on rubber mounts or no but I will still see about replacing the asbestos either with a steel sheet or a chunk of exhaust gasket material, in AC sets the paper caps are not the only things that can melt and burn there is also the power transformer with tar and varnish inside it.
Bob,
They did stuff those babies with wires....
Here is good news!
I had the decals made from Radiodaze and he was adding them to the site.
When the site got redone he must have forgotten to add them.
If you only need one then I can throw one in the mail.
If you need more then you can just call or email them with the part # DCL-ZE-6R631
Me
Thanks for the tip arran, I'll find some shims or washers to lift the chassis a bit.
Thanks Kirk, but sam sent me some of those, an exact fit! OK, I won't repost that jammie picture of you Icon_lol
Icon_lol
Me
Well, when you replace the caps you will have plenty of room, why not replace the carbon resistors at the same time for another buck or two? Snazzy set!
Thanks codefox but I'll be restuffing those paper caps so won't be gaining any room that way ... I know... glutton for punishment.... I do like the way the set looks.
For some reason I always like to start by changing out the electrolytics.  This one wasn't too hard to get to.  A few paper caps to take out first and a handful of leads to disconnect.  I opened the can by rolling the blade along the raised edge until it penetrated the can, same approach as a tube cutter, slow pressure while rolling.  I'll epoxy the can back on after its up and running.  Most of the label is still there and a little glue helped fix some spots that were loose.  So here are more pics than most would want of this  Icon_smile
[Image: https://www.dropbox.com/s/rx8qxkyqvh66f5....jpg?raw=1][Image: https://www.dropbox.com/s/izr0oiavxdx6gh....jpg?raw=1][Image: https://www.dropbox.com/s/t51cafhj17g0uh....jpg?raw=1][Image: https://www.dropbox.com/s/00bq0ysyjemvb3....jpg?raw=1][Image: https://www.dropbox.com/s/3bhx7xel9icha5....jpg?raw=1]
 That electrolytic was a replacement anyhow, the original would have been a Zenith branded one, possibly with a black cardboard sleeve, not a Mallory brand one with a blue and red label, so I wouldn't worry about preserving the label too much.
Thanks Arran. Now that you mention it, I did see a black cardboard covered electrolytic in the restoration I saw someone else doing online so I suspected mine was a replacement.
Am continuing to recap and check resistors.  So far resistors have been amazingly on spec.  I did replace one dogbone with a carbon composition.  Most of the Zenith caps are similar to Philco caps with a cardboard tube with wax caps on each end of the foil cap.  I did run into two Zenith caps that were thin paper over a wax cylinder that completely covered the foil cap.  Fortunately I was able to slide the paper off of the wax without any heating and without damaging the paper.  For these, I built up the diameter of the new yellow cap until it was the same as the paper and would thus provide some stability to the stuffed cap.  I then fill the remainder with hot glue.  Here's a picture of one of these after sliding the paper off of the wax cylinder containing the foil cap:
[Image: https://www.dropbox.com/s/s3lbbpt88cve67....jpg?raw=1]
I'm a bit better than half way through the recapping.  Everything left of the yellow line is recapped.
[Image: https://www.dropbox.com/s/s43mwb4b4op5eb....jpg?raw=1]
VTVM meter moves when my hand is next to it & not on
This is strange to me.  Maybe in over 50 years of working around swinging, analog meters I just never saw this, I have m...Bruce B — 03:14 PM
Interesting thought, Rod. Our 1947 Zenith console has both FM bands, so presumably it could be done with appropriate cha...EdHolland — 03:03 PM
I suppose it's too much work to modify the oscillator for the FM tuning 88-108.RodB — 02:41 PM
I also have a 7H820. Nice little radio and I use it often. Obviously the old FM band is quite useless! It's only use ...rfeenstra — 02:37 PM
The mica save was inspired/encouraged by this gem I found: I'd wondered if it could be done, and for this style of...EdHolland — 12:16 PM
AES type of Battery Eliminator has hum in B+
The power supply was on Phil's Old Radios web site I did add a isolation transformer. DavidDavid — 11:32 AM
Something to look at have one and like it. David   David — 11:29 AM
Well, I like to keep it simple and didn't want to mess with perf board. Plus, the owner of this radio is a relative of a...RodB — 10:58 AM
Rod Yes, your standard TO-220 LDO is good for 0.7 - 1.5W dissipation (more with a heatsink) and a small current wit...morzh — 10:11 AM
Mike, I did find an LDO to give me the 90 volts and I got real excited when I discovered it but then I discovered it's ...RodB — 09:57 AM
There are currently 1249 online users. [Complete List]
» 3 Member(s) | 1246 Guest(s)
