40-190 swap speaker to permanent magnet
I am working w/ the speaker on this unit that does work but it has some vibration at higher frequencies.
You can hear it pretty much all the time but really bad with music. Lower voice radio shows sound better.
I'm thinking the coil is vibrating or something down in that area.
Currently trying to see if I can center it better.
Thinking that just swapping to a perm mag setup may just be the best bet.
What is needed to do this if I end up down that path?
I was advised to have the speaker rebuilt. The electromagnetic acts to lower hum. My 37-665B is being rebuilt and I expect it to really sound good.
What you will have to do (and I would advise against it unless it becomes a necessity - try to align the speaker first) is:
1. Get the speaker with the proper voice coil impedance. If not possible and the impedance difference is too great (like 8 Ohm vs 0.67 Ohm) you will have to change the output transformer or the speaker will not work very well.
2. In case the radio is small and the coil was not used as the filter this would be it. But it is rare.
3. If it is used as the filter: Replace the field coil with equal or close value inductance choke. This will have to be mounted on the chassis or special precautions used not to propagate interference using long wires (twisting etc).
4. The choke has to be current rated at least the same or better as the field coil.
5. The DC resistance of the choke has to be very close to what it was in the field coil. If it is lower a series resistor of the appropriate wattage has to be added.
6. Last. In some Philcos a capacitor across the choke is used to minimize ripple (works on phase differences). If the choke is different it might not be effective. So the value may have to change, or the cap might not even be needed. In any case, the second cap after the choke can be increased without much ill effects and this will attenuate the ripple more.
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
