Model 91 Console chassis in Model 91 cathedral?
I have a Model 91 console in the queue with lots of veneer issues.  Would the chassis from this console fit into the cathedral cabinet listed on eBay?  I may be interested in this listing and make the swap.
http://www.ebay.com/itm/PHILCO-model-91-...SwPc9WvnBy
Yes.
(you may have to make sure it does not have metal mounting feet sticking out from the bottom of the chassis as in some 1933-34 Philco console chassis)
Yes you can like Ron said, I asked that same question and I indeed did it. Here are some pictures of mine. 91 console chassis in a 91 cathedral cabinet. I did have to find the speaker that worked.
Hmm, I don't have a speaker for a cathedral cabinet.
Good luck finding one...K-6, 3275 ohm field.
I did the same thing you are wanting to do - I had a 91D which soneone had slopped over with polyurethane. Rather than attempt to strip that, I gave the cabinet away at a swap meet to a collector, found a 91B cathedral cabinet, and put the 91D console chassis inside the 91B cabinet.
I still need to resolve my own speaker issue. I kept the original 91D speaker (H-12), and removed the field coil and "pot" from the console speaker. I still need to mount that field and "pot" onto a K series speaker. I'll also use the original output transformer on that K series speaker.
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
There are currently 7784 online users. [Complete List]
» 1 Member(s) | 7783 Guest(s)
