Philco 48-1263 turntable
Hey all,
Doc here. I posted about this radio/phono last April. I've come a long way since then (I had just started trying to restore radios and had never held a solder gun) but I am having turntable issues. I bought a replacement cartridge from Ed Crockett and the phono worked fine- for a while. This morning I was playing Nat King Cole when he started to kind of- quaver? You know, up and down like the turntable wasn't running smoothly. And the more I fiddled with it, the worse it got until now it plays noticeably slower overall along with the still- wavering sound. What should I look for as the culprit? All I did so far was to spray WD40 into the motor and blow it out with a compressor, took the hard-rubber wheel off and cleaned and replaced it, and checked the wheel for runout with a micrometer. It doesn't appear to be out of round but that's sure what it sounds like. Actually the wheel looks to be in great shape. Pile on! I need advice.
Doc
Clean off the shaft coming out of the motor, drive wheel, inside edge of the platen, and anything rubber that you got WD-40 on. IPA should work to clean things off with.
Thanks Terry. Hey, everybody knows that was a joke about checking runout with a mike, right? Well, it sounded funnier in my head. Yeah, I cleaned up everything, The capstan, inside the platen, the wheel ( I took the wheel off before the WD40 spray), it still runs a little slow and has that darn drag on every rotation of the record. Also the turntable used to immediately start spinning at correct RPM but I noticed now it takes a turn or two to get up to speed. There's a spring that holds the wheel against the capstan; could that spring be stretched? It still works but I don't know what kind of tension it should have.
Doc
Philco Model 80 Transformer resistance
Just forget this number, it is useless anyway. Simply proceed with your project.morzh — 10:08 PM
My $0.02 is that it is a misprint. I tried to look up the value for the similar 84 and 37-84, and ther is no resistance...MrFixr55 — 09:51 PM
Thanks for the quick reply! Hmm...well that's good, so what am I seeing that's 1042 ohms on the schematic for the pow...Mike L — 08:46 PM
The DC resistance of the primary is 8 to 9 Ohm.morzh — 07:54 PM
I have a feeling the primary winding on the power transformer is bad. My resistance reading on the primary side is 9 ohm...Mike L — 07:48 PM
Rusty Tuning Condenser
I would try Naval Jelly and use a soaked pipe cleaner to get it where it needs to go.RossH — 06:56 PM
38-10T chassis Restoration begins
Hello Dconant , they sold mica to use as a insulator between transistors and their heatsinks too. Rob I will remove th...radiorich — 02:52 PM
Thanks for the info guys. I always wondered why the use of mica. Now I know.dconant — 01:52 PM
Most common plastics have a dielectric constant in the 3-4 range whereas mica is around 6. This means that even if you w...Steve D — 01:46 PM
It is acceptable but not desirable. Plastic is not an approved cap dielectric, and even though a reasonably thick piece...morzh — 11:52 AM
