Output transformer for Philco 39-17
Threads: 29
City: Richland, Michigan
I've acquired a model 39-17. Nice looking little radio. I'm looking for an output transformer. The output tube is a 41. RCA literature for the tube says the load resistance is between 10,000 and 12, 000 ohms. The original primary resistance is 700 ohms. I've only replaced an output transformer once before with Ron's advice. Looking for the right transformer amoung the Hammond single ended universal series. As well, I'm not sure about the secondary lead choices. Let me know what might work or if there are less expensive choices out there.
Dave
Threads: 572
700 Ohm has nothing to do with what you need. Or almost nothing.
You size up your transformer by the allowed wattage and then see if at your load impedance (say 4 Ohm) the input of the transformer gives you your 10 - 12kOhm.
So,
http://www.hammondmfg.com/pdf/5C_125SE.pdf
Step 1: get your speaker voice coil impedance (what is it?). Say it is 4 Ohm.
Step 2. 4 Ohm will yield 10,000 Ohms primary impedance if connected to BLK/ORG leads.
If your Voice coil impedance is different, see the chart for what you need. Basically the PRI impedance = VC impedance times square of the turn ratio.
Threads: 29
Okay, thanks. I'll measure the voice coil tonight. Thanks for your help.
Threads: 269
(05-05-2016, 11:40 AM)Sourbone Wrote: Okay, thanks. I'll measure the voice coil tonight. Thanks for your help.
Methinks your going to measure the resistance of the vc which is not what you need to know. Impedance is what you are looking for. The simple answer is try first few low impedance taps on the transformer secondary for loudest/ least distortion. More that likely it's going to be around 2 to 8 ohms.
Threads: 572
Well, to make it easier a bit:
The impedance of the VC is never lower than the guaranteed "minimum impedance" which is the DC resistance of the coil.
Then for calculations is so called "nominal impedance" is used which loosely describes the behavior over most of the audio span.
This is given as 1.15*Zmin so it is about 15% higher than measured DC resistance.
It is imprecise but quite OK for transformer pickup.
In any case it is NOT going to be lower than the DC resistance.
So, DC ohming out is still useful.
PS> Again, this works for a single speaker. Not for acoustic systems that have crossovers and that complicates the heck out of calculations. But in this case it is the single speaker.
Threads: 29
The Philco literature for the radio says its audio wattage is 2 watts. It looks like I should probably use the Hammond 125ASE and the secondary leads ORG and BK. Thanks for your help.
(This post was last modified: 05-05-2016, 04:06 PM by Sourbone.)
Threads: 572
So your speaker has 4 ohm VC?
Threads: 29
The voice coil measures 1.3 ohms.
Threads: 572
Well.....125 SE though will work, is not the best one for the job. Your impefance is really low for it to match it well.
I was always surprised by the fact that 125CT does provide good match for low impedance speakers and SE does not.
I bought my xfmr for a similar speaker from Your Oldradioparts.
If you still are going with 125SE then yes, Blk/Org is the best one.
Threads: 29
You know it seems Philco speaker voice coils are commonly low in impedance. I just repaired a model 650 where the voice coil was 1.1 as it was written on the Nostalgia air scan of the schematics. A model 39-40 I worked on has the voice coil impedance at .25 ohms. Might that low impedance contribute to the primary opening up?
Threads: 572
No why would it?
They specifically use transformers with high turn ratio so the primary presents as a proper impedance....
In Philco 20 the turn ratio is 100, one of the highest so it converts 0.7 ohm into 7kOhm.
Threads: 18
Most tabletop tube radios of that vintage are not very fussy about exact impedance matches, no harm in trying something similar you may have on hand. Exception is for "portables" which have such low output that a severe mismatch reduces volume significantly. At least that's been my experience.
Thanks for the replies, I will check these ideas out and report back.
murfmurf — 03:18 PM |
Sorry, my mistake.
murfmurf — 03:07 PM |
MrFixr
Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM |
Two small radios from France. Restoration and review.
Greetings;
I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM |
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM |
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM |
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM |
Hi Morzh,
From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM |
Any reason for the 2nd copy of the thread?morzh — 10:22 PM |
Sorry Murf, technical is what I do.
OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. Th...MrFixr55 — 09:31 PM |
There are currently 909 online users. [Complete List] » 1 Member(s) | 908 Guest(s)
