ID of Philco's
All, Here are 3 pictures of some Philco radios. I cannot find a model number on any. Can someone please ID ?
Thanks
Skip...
[Image: http://i292.photobucket.com/albums/mm38/...bhzoyl.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...snhlof.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...lc6f1i.jpg]
Found at antique store..
Alll 3 are post war sets. 46-1201, or so, 47-1230, and a 46-350. You can find them here  http://philcoradio.com/gallery/#list
Terry, Ok thanks.. the one looked closer to a 46-1209 ..
instead of a 47-1230..
Skip...
 The first set could also be a 48-1201, which was the same set but with some miniature tubes, and slug tuned IF cans, I believe that the B+ voltage was higher as well.
http://www.philcoradio.com/gallery/1948a.htm#w
 The console is a 46-1209 and the last set is a 46-350, unless it has an imitation alligator covering then it would be a 48-360.
All, Ok thanks.. Just a quick Question.. What are these worth.. Consider them Not working..
So I know what to offer..
Skip...
All, Ok picked up all three radios for 25.00 each.. Cabinets are not in great shape. But radio itself looks OK.. Will not know until I start to pull apart.. Parts are probably worth what I paid..
Thanks
to ALL
Skip...
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
There are currently 3772 online users. [Complete List]
» 2 Member(s) | 3770 Guest(s)
