  • 1 Vote(s) - 2 Average
Philco 90 Lowboy
I can't remember if I ever shared a picture of this unit or not. It came from the same place as my 70 Lowboy came from. I have a feeling the tube shield and knobs were robbed off this for a 90 Cathedral, so decided to use the tube shields off a very burnt up Majestic model 21. Power transformer is ok. Doesn't pick up any stations, but it gave me a nice hum from the speaker when I got close to full power on it. Hey, audio is audio. At least I know the heavy iron is ok. These are neat little lowboys and it seems Philco sold about as many of these as they did the cathedral. I just wonder how many of these have been sacrificed over the years to repair the cathedrals though? Icon_eh
Jayce;
  Which model 90 chassis does your lowboy have? The early, middle, or late production one? The early had push--pull 45s, the middle had a single ended #47 but had AVC, and the late had push-pull 47s. The early model 90 is easy to spot, it has a local distance switch on the back apron.
This has the middle production chassis with a single ended 47. Would be really cool to find a unit with the push-pull 47s. They do pop up around here from time to time, but most seem to be the single 47 with the occasional unit with push-pull 45s.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1125 online users. [Complete List]
» 1 Member(s) | 1124 Guest(s)
