nice,simple 2-tube compressor schematic:
I found I needed a compressor to keep all my various CDs output levels the same at the input of my homebrew LPAM transmitter. By adding this simple compressor, allows me to run full 100% modulation from my LPAM xmitter, without having to make input adjustments from various CDs recorded output levels.
I found a nice-simple schematic online that works very well! Thought I would share it here. Most vintage radio restorers/techs will have the parts needed for this project onhand in your scrapboxes. The ac trans is not shown in the schematic, but ( adding it),..is simple to understand. I used a small ac trans with 117-125 v primary, and 150-ct-150 hv secondary, with a 6.3 volt tap for filaments supply.AC trans HV rect c.t. goes to chassis ground. Rectification is via (2) 1N-4007 diodes + to tubes plates via 1 connection point from trans h.v. leads. AC hum is filtered via a 100uf/ 350 v cap at B+ to chassis gnd.
As for the variable-resistors, I used a spare 1-M audio taper, & for the 25k, I used a good spare linear taper. It works well.
The 10uf electrolytic in the schematic , I used a spare 350v type. I used new carbon/comp 1/4 watt resistors throughout, and added a couple used 1/4 in female switchcraft connectors for hookup.
Heres the very simple 2-tube compressor schematic: ( many other good schemats at this site also!)
http://www.triodeel.com/comp1.jpg
Icon_wink
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
