Threads: 373
City: Dover, OH
Threads: 310
City: Kings Park NY
What!
Ok thats bull...
I want one,
AC: 4 DC: 1
Threads: 437
City: Boston
15 for a wood set that vintage that condition equals good deal, IMHO.
Jayce;
It appears that the control above the volume know is supposed to be there, at least from what I found in a photo of another example of this NA model. As for the style of the knobs the photo of the other example has knobs of a different style, but also wood, whether those are the correct knobs or the ones on your set are I don't know, it may have been a production change since FADA was basically a mid sized regional make.
Threads: 40
City: Sanger, CA
I'd say that $15 for that Deco beauty is not just a good deal, it's a smokin deal!!!!!! If you decide it doesn't fit in with your collection, I know where it will......
(This post was last modified: 09-04-2016, 01:00 PM by SteveG.)
Threads: 373
City: Dover, OH
It's good to know that I got a steal with this radio. It does look like there is nothing major wrong with this set. I pulled the chassis today and managed to get that one control clean and moving like it should and, other than the speaker being loose due to deteriorated rubber washers, didn't see any issues. I had seen some rubber coated wires on the top of the chassis and feared a rubber wire nightmare under the chassis. Luckily, that isn't the case. It is a bit cramped under there though and I see that some caps will have to be removed before even replacing the power cord. Still, I've seen way worse and it appears to be mostly unmolested under the chassis. Only mistake I made was not testing the tubes while the radio was apart. Hopefully I can get them out later.
City: Sedona, AZ/Placentia/CA
Jayce, you should be arrested for stealing. What a great price on a nice radio. Post your restoration so we can all enjoy.
Best, Jerry
Threads: 40
City: Sanger, CA
Jayce,
Hoping your restoration will only be an internal one. The finish on the cabinet looks like it should clean up real well!
Threads: 373
City: Dover, OH
The finish is decent on the cabinet. There are issues with the black lacquer on the top. A small portion along the front edge is missing and there is what almost looks like a split going right down the middle of the top. I am wondering if there might be some fix to sort of blend those spots back in?
Threads: 373
City: Dover, OH
I am sorry to say that all radio projects will be going on hold until my work situation improves. I'll be keeping this one though, no worries there.
