Emerson 350 aw
(11-11-2016, 04:54 PM)Radioroslyn Wrote:  What is it with you and IF transformers?????
Have fun!
Thanks Terry!
Icon_lol  yes it does seem like I'm cursed although the last IF xformer problem was all of my own making when I mis-wired something and proceeded downhill from there.  This time I haven't done anything but take the big electrolytic cap box out and tease out the old capacitors from the box with some heat and patience...
[Image: https://www.dropbox.com/s/8x29igxws426un....jpg?raw=1]
[Image: https://www.dropbox.com/s/dosu4ob4sezhnt....jpg?raw=1]
Looks like things are unfolding!!![Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
Now I think I've got it!
(11-11-2016, 11:22 PM)Radioroslyn Wrote:  Looks like things are unfolding!!![Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
Icon_rolleyes   Icon_lol
Woah!
http://www.ebay.com/itm/EMERSON-CHEST-TY...7675.l2557
You didn't...did you?
Thanks for posting that Kirk, it gives me some good pictures of the finish.
But what the heck is this?????? (picture is from the emerson in Kirk's post)
[Image: https://www.dropbox.com/s/7014ktqrekayk1....jpg?raw=1]
Mine definitely does not have that.  It looks like someone added a candohm resistor that drops the line voltage?
I've finished stuffing the old electrolytic box.  Next will be taking out the paper caps and resistors and taking out the transformer that seems to be open.
[Image: https://www.dropbox.com/s/l14wstljku27zs....jpg?raw=1]
This is what I think is a buck resistor that probably use to drop the voltage from the AC Mains to the filaments.
Or a Candohm, pardon my French.
>buck resistor[Image: http://philcoradio.com/phorum/images/smi...on_eek.gif]
???? I think here in the states we call it a dropping resistor. Never heard of one being named after it's price.[Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
Sure looks like something is lost it's lunch inside the cabinet.
(11-14-2016, 05:23 PM)Radioroslyn Wrote:  >buck resistor[Image: http://philcoradio.com/phorum/images/smi...on_eek.gif]
(and I meant to say "bucking") - yes I know we call it dropping resistor. I just felt creative and named it after the action it performs. Which is, well, a bucking action after all. Icon_lol
Isn't that the thing you sit on and drop a quarter in in front of the food store???
When I see bucking I think of a transformer using the pri connected to one side of the sec to buck out of phase or in phase volt adding or subtracting the sec voltage's. Like a bucking transformer. Resistor don't necessarily care about the phase relationship.
I know I have too much time on my hands[Image: http://philcoradio.com/phorum/images/smi..._crazy.gif]
 I've heard of curtain burners, as in resistive line cords, so that's the first cabinet burner I have seen. That is an absolutely stupid location, not only is it a shock hazard but it's a fire hazard as well since candohms are supposed to be mounted to a metal plate to dissipate the heat.
 With regard to the Emerson 350 on fleabay, it's way too high of a price in my opinion, but assuming that one might be worth $125-150 restored it would be well worth reproducing a proper wood replacement door for this set since Terry has one to make a pattern with.
(11-15-2016, 06:19 AM)Arran Wrote:  ... it would be well worth reproducing a proper wood replacement door for this set since Terry has one...
Thanks Arran, I'll be attempting a reproduction of the door.  I can use my good door as a pattern.
[Image: https://www.dropbox.com/s/yy31aa3s67zt2j....jpg?raw=1]
I got the IF transformer out that had the open coil and unfortunately there was not anything obvious that was causing the open.  The two ends of the coil were solidly connected to the lugs.  I re-heated the solder at each lug to see if that would help, no dice.  I unsoldered the two ends of the coil, sanded the ends clean and rechecked continuity...no dice.  I uncoiled the first turn of the coil and it came off nicely so no break at the very beginning, and I can't unwind from the bottom...so it looks like this coil is dead unless someone has another idea.
I don't have any old Philco coils lying about as Terry suggested but I think this coil from Antique Radio Supply should work.  https://www.tubesandmore.com/products/coil-oscillator  Is that correct???
Can I just wire it in directly like this????
[Image: https://www.dropbox.com/s/f3795czz6w5dqi....jpg?raw=1]
No. That coil is for the oscillator. What you need is an IF transformer. If you had a spare 455kc orc so transformer you could dissect one of it's coils and mount it in your current transformer. Must have trimmer cap to adj not a slug tuned one and has to fit in your old can.
Darn...OK thanks Terry. I will see what I can find.
There are currently 2589 online users. [Complete List]
» 2 Member(s) | 2587 Guest(s)
