I have got a 40-195 that I got from antique strore.I had the chassis out cleaning it and noticed what looks like little electric motors on the tone and volume controls. Are these motors or something else? If they are motors do they turn voulme up and down or what? The tube light up but just makes noise. Is it worth fixing? Thank You for the help Mike
Hi
No, the tone and volume controls do not have motors on them. Each does have a gear on the end of each control shaft; this gear contacts teeth in the tone and volume thumbwheels, respectively. This gearing is what makes the controls operate.
Sometimes teeth break off either the tone or volume thumbwheel, or both. Where the teeth are broken, the thumbwheel cannot turn the control up or down. This can only be remedied by finding another thumbwheel from a junker set. The thumbwheels are made of Bakelite, and the teeth on these can be broken easily if you try to force the control.
Now, as to your other question. Is it worth fixing? That depends. If you plan to fix it up to resell, then no. If you want to keep it and enjoy it, then yes. One man's opinion...
Finally, please do not plug it in and turn it on again until you have, at a bare minimum, replaced the set's electrolytic capacitors and tested the tubes. More info on that subject here.
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Rogers Majestic R-646
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
Hello Rod " If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover ...osanders0311 — 06:25 PM
Vlad; My set had the same faults as yours when it was about 30 years younger, so I think that these components are sus...Arran — 05:11 PM
If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover caps.RodB — 04:56 PM
There are currently 353 online users. [Complete List]
» 3 Member(s) | 350 Guest(s)
