Philco 57
It has been awhile since I have posted. Haven't really been doing Philcos, but that has changed. I just received a 57C and was blown away by how clean and original the chassis was. I just dusted and this is what I got. It looks like one resistor had been changed aways back and they put their fingers through the speaker. Here are some pics. Tell me what you think. It also works and the cord appears original too!
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Thats a cherry one! It must have belonged to the same little old lady that only took it out of the closet on Sundays to listen to a church program. She had some nice cars too!
Wow! Nice score. Icon_mrgreen
tractorforum.com *** I reserve the right to be wrong
Thanks for the coments. I have been playing it for about twenty minutes a day since I got it and it plays great. To hear Big Band and old time radio coming through the original electronics like it did in 1933.
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
