Where can I buy solid hook-up wire
Are there any suggestions for finding reasonably priced solid conductor vinyl/rubber hookup wire for rewiring a chassis or for a kit? I have checked Mouser, AES (only can find the cloth covered wire or stranded rubber), NTE and Amazon.
https://www.amazon.com/Hook-Up-Solid-Spo...olid&psc=1
On this, it doesn't specify voltage, so I assume it is 300v, which probably isn't adequate for rewiring the B+ circuits. I tried the wire from AES, and it is stranded, which is more difficult to get through terminals, and I already found it is easy to get a strand bridging a couple terminals. May try tinning, but from my past experience it makes it more difficult to bend and harder to get through small holes. But, may be my only option. Maybe the 300v is ok for all except for the higher voltages. Any suggestions appreciated.
Tim
Try RadioDaze: http://www.radiodaze.com/cloth-covered/
I got mine from the Daze also.
Thanks Bob! That put me on the right track. Been looking in all the wrong places. Icon_problem  They have just what I need, and it's at a reasonable price. Icon_e_biggrin
Tim
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1096 online users. [Complete List]
» 2 Member(s) | 1094 Guest(s)
