HEATHKIT SG-8 SIGNAL GENERATOR unknown mod?
I have a heathkit sg-8 that some one has modified
They put a 8 pin socket on the right upper side.
Pin 5  goes to pin 1 of the 12AU7
Pin 6  goes to RF out jack
Pin 7  goes to ground
Pin 8  goes to 6.3 Vac
I ask to find out if any knows of this mod?
 If so what tube should I get?
My guess is this tube is amplifying the RF.
This is the front of the SG-8
This is the back
I doubt it's a socket for an additional tube, probably for some sort of accessory. Maybe an 100kc calibrator.
Now I think I've got it!
With the signal gen  hooked up you could monitor rf plate voltage on the 12AU7 and filaments for stability?
HEATHKIT SG-8 now up and going
There are currently 4132 online users. [Complete List]
» 1 Member(s) | 4131 Guest(s)
