Threads: 88
City: Tacoma
Trying to resurrect a volksempfanger. It came in messed up pretty bad: busted slide rule dial (paper dial sandwiched between two pieces of heavy plate glass), output transformer ripped off the speaker and all the wires torn loose from the transformer, and, last but not least, one busted tube. Didn't even SEE that it was busted until I really dug into it, I thought it was just the oddball cap being loose. [Image: https://www.facebook.com/images/emoji.ph.../1f641.png]:(
Now, here's where I hope somebody can point me in the proper direction.. the broken tube is listed on the schematic as an AF7, but the tube in the set says Telefunken 48, which I can't even find a listing for. Can someone advise me if these are equivalent tubes?
(This post was last modified: 12-07-2016, 09:34 AM by BrendaAnnD.)
Threads: 573
Radio museum with their German background could have some info.
Also ask on Peter's forum - they deal with VEFs (not sure why you called it Volkempfaenger, it is Latvian, Latvia became a Soviet territory in 1940 I think).
Threads: 88
City: Tacoma
Mike,
Because that's what they call it. Several different cabinets with the same chassis, all called volksempfangers. Think this one was made in Bavaria. I've got two others coming as well, same circuit, different manufacturers, all part of the German propaganda system. Perhaps what you're thinking about is a Latvian brand name, rather than these?
Threads: 88
City: Tacoma
I see the problem... that "F" doesn't belong there, so I got the "F" out of there..
Threads: 573
Aha....yep. VEF was Latvian photo and radio manufacturer, pretty famous too.
Threads: 54
I remember running into a website about Volksemfanger sets a while back, I even bookmarked a page about them either posted by someone in Germany or Austria. If I remember correctly they all seemed to use a three tube regenerative circuit, but I don't recall whether they all had a power transformer or whether some were series string. AF7 sounds like it would be the proper type from what I could find about most other VR301s. Unfortunately the Germans, like the British, seemed to have this silly predisposition to using 4 volt filaments in many of their tubes, which seems to lack any rhyme or reason. It looks like its an expensive tube too if fleabay BIN prices are to be believed , I wonder if the 6.3 volt EF7 is cheaper. Basically it's an RF amplifier pentode of some kind, at least with this you can work out a substitute if there is one. Maybe you can make an adapter out of it's base and use a cheap and useless series string TV tube like a 4BA6?
http://tubedata.tubes.se/sheets/030/a/AF7.pdf
(This post was last modified: 12-10-2016, 05:17 AM by Arran.)
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM |
Hello Ed,
yes, I like letting projects run for few days to make sure they don't start acting up .
Sincerely Richardradiorich — 01:03 PM |
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM |
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM |
Refinishing Ideas
Hi Doppelganger,
After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM |
Philco model #20
Hi Rick,
One other thing regarding volume on this set. Make sure that the tube shield is in place. this is that la...MrFixr55 — 08:22 AM |
Philco model #20
Hi Rick,
The volume control on the Model 20 has 2 sections and does 2 seperate things:
One part of the control, ...MrFixr55 — 10:30 PM |
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM |
Yes - better it happened on the repair bench than returning to the owner.
The other question is - do I also dissect a...EdHolland — 09:08 PM |
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM |
There are currently 734 online users. [Complete List] » 1 Member(s) | 733 Guest(s)
