#46
I'm using the BNC connector jack or the regular input output jack?
#47
Ok I'm sorry. I see what you mean. I only have the BNC type connector that goes into the RF output jack. I don't think I have anything currently that will go into the input/output jack.
#48
If you have some large dia wire or a couple of nails that that fit w/o forcing your good.
Ok I've got a couple of good cables with banana plugs. I connected to pin 2 of the 41 tube and can hear the audio frequency output from the sig generator. Can you advise me on working my way back through the stages?
#50
With the radio powered pin 4 of the 41 gave a loud signal
#51
Pin 2 of the 7C6* though a cap and then pin 3 on the 7C6. Next will need to set the sg to produce a rf signal. Set frequency range on B and adjust dial for 455KC. Turn up the attenuator Apply signal to pin6 of the 7B7 closest to the 7C6. Do like wise with the other 7B7. Next *pin 2 of the XXL closest to the IF transformer and pin 6 also . If all is well you should hear a 400cy tone when connecting to these points. *Be careful some of these point have HV connected to them.
Ok 7C6 pin 2 strong sig; pin 3 faint sig.
7B7 pin 6 strong sig.
XXL pin 2 strong sig; pin 6 faint sig.
#53
BTW I have a 0.01 mf cap on the end of the hot lead from the sig generator and the radio is plugged into an isolation transformer
#54
Also, just an observation, the radio often gives off a tone even when the hot lead is just near it
#55
Ok good. While we have the sg all warmed up let peak up the IF stages. Connect the 455kc signal to pin 6 of the XXL. Adj #'s 29Aand B, 32A and 41A for max tone in spkr w/the sg attenuator turned down so you can just hear the tone solfly.
Ok its tuned. It didn't take much
#57
Ok let's revisit the plate voltage on mixer XXL (one you have been connecting the sg to) and the oscillator XXL. What are they??
The voltage on the first XXL tube, pin 2 is 39V. On the second XXL tube pin2 is 146 V (that was the steady value after drifting downward for a time). These values are measured with the black lead touching the chassis.
#59
Now you know that's not the right answer!!!!!
Measure the resistance from pin 7 to the chassis on the xxl oscillator tube.
That w/the set off.
Powered off the resistance between pin 7 of the first XXL tube and the chassis is 0.6 ohm
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1038 online users. [Complete List]
» 4 Member(s) | 1034 Guest(s)
AvatarAvatarAvatarAvatar
