#61
lol Icon_lol
I like how you phrased that
Now you know that's not the right answer!!!!!
sam
I think 0.6 Ohm is what it should be
#63
Or "less 1 ohm" ?
#64
Or is it "less 0.1 ohm"
#65
I think Sam is referring to the missing punctuantion after "powered off" Icon_smile
Truthfully, took me a while to understand it too Icon_lol
"EXECUTE NOT PARDON". Which one is it? Icon_lol
#66
I think there is a disconnect. I was just saying the the resistance from pin 7 was measured to be 0.6 Ohms with the radio powered off. Then I was following the line from the pin on the schematic and was thinking that the resistance is written as "less 1 ohm" or possibly it says "less 0.1 Ohm" there.
But I did have a laugh at "Now you know that's not right"
#67
Still not the right answer!
I was looking for something open.
Ha! Ok what's the right answer? That tube should be 70V but its low. We tried disconnecting one end of 17 a week ago but that didn't raise the voltage.
#69
Ok I'll look for something open
#70
Well there isn't anything that isn't supposed to be
#71
(12-08-2016, 10:23 PM)ccbaker13 Wrote:  Well there isn't anything that isn't supposed to be
Well as Peavey the druggist would "I wouldn't say that"! The voltages aren't.
Does #27 measure 4.7K? and what are the voltages on both sides of it.
I get 4.7K and 10 volts across it
#73
Oh sorry, 190V and 200V
#74
Reminds me of chess playing Icon_lol
#75
Yeah this radio is Bobby Fischer
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1090 online users. [Complete List]
» 3 Member(s) | 1087 Guest(s)
