Philco 46-350 restoration
I am in the process of restoring a Philco 46-350 portable radio. There are two wires that are not connected. One is very easy. It is the blue antenna wire. The other one is a little strange. It comes up thru the chassis next to the volume control potentiometer. The wire clearly shows in the Riders schematic. This one has cloth electrical tape around the disconnected end. Does anyone know where this end goes?
Terry Hicks
I just looked at mine I am restoring now.. I do not have a wire coming up there.. Look under and let us know whats its connected to and I can look at mine to see where it goes.. If anywhere..
Skip...
I have this picture from the restoration I did on my 46-350. Unfortunately I don't have access to the radio at the moment but the picture clearly shows a taped off wire just like you have. I just left mine taped off like that if I remember correctly.
[Image: https://dl.dropboxusercontent.com/u/5462...46-350.jpg]
I have restored a 46-350. They all have that wire, I believe it is for aligning the radio. It certainly doesn't need to be connected to anything, my radio works beautifully.
Yep I have 2
1 with and 1 with out wire
Sam
they all have that wire,,,and ,,nobody really knows ,,,were it goes and what it is for,,,,,I ,,don't believe that,,,you just pulling our leg,,,lolololol
Mine doesn't have the wire either..
Skip...
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1021 online users. [Complete List]
» 1 Member(s) | 1020 Guest(s)
