6A3 replacements
I finally got my Philco 116X working, but with a borrowed pair of 6A3 output tubes. Reception and audio quality are outstanding.
Short of buying a working pair of 6A3s at current prices (thanks, audiofools) what might be recommended as replacements? 6B4G is electrically the same tube, octal base, same high prices.
Changing the tube sockets / types is heresy to many on the forum, but this set is no beauty queen. I'd like to enjoy the set as work bench company. All electronics would be completed neatly and to a high standard, as has the rest of the chassis.
I considered using a single 6AS7 with its two sections in push-pull, or a pair of triode connected 807s with operating voltages accordingly changed. Those types are already on hand, in storage. I believe those choices could approximate present current draw from the power transformer, audio output transformer impedances, and available audio power output.
All help is greatly appreciated!
Keep warm, this weekend.
-O.B.
I don't know what the audiophool prices are but you could get a pair of these used. I've bought from him before and had no problems.
https://docs.google.com/spreadsheets/d/1...0foD#gid=1
Bob Dobush got me my pair of 6B4 for a very reasonable price.
I don't see any reason to screw up a perfectly good radio.
+3 for Bob Dobush... Icon_thumbup Icon_thumbup
I have used Bob  Icon_thumbup No problems. One tube was noisy, he was quick to make it right. Very fast communication. And reasonable.
Joe
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1021 online users. [Complete List]
» 1 Member(s) | 1020 Guest(s)
