Doerle 2 tube build.
Hi,
I'm getting ready to build the radio and have a question. On the schematic where does the other side of R2 connect? Does it go to ground?
Andy
(12-17-2016, 06:00 PM)Andy Wrote:  Hi,
Andy
Hi Andy,
This question is probably better suited for the Other Radio topic. Moderators will move it. No big deal. Happy to entertain your question, am familiar with the Doerle but would be helpful if you could link or post a schematic. I'm sure there are several around so I just want to be sure it's the same one you are using.
Thanks, Terry and sorry. I just assumed everyone on the Forum knew this radio since Ron built it and it is part of the site.
I moved the thread.
Andy, I don't know if this LINK is what you are referring to but I suspect it is. If so, that's actually Chuck Schwark's Philco Repair Bench site.
(12-17-2016, 06:15 PM)Andy Wrote:  Thanks, Terry and sorry. I just assumed everyone on the Forum knew this radio since Ron built it and it is part of the site.
Oh you mean this one?
http://www.philcorepairbench.com/doerle.htm
On R-2 the one end is not connected, it's in series with the filament and controls the filament voltage and the gain of the tubes. If you did connect (which you shouldn't) that end to ground it would run your A battery down in short order.
Happy regenerating!
(12-17-2016, 06:26 PM)klondike98 Wrote:  I moved the thread.
Yes, that is the schematic and thanks again. The colors and make-up are very similar.
Thanks, Terry and Bob......I need to pay more attention!!  Icon_wink
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 769 online users. [Complete List]
» 2 Member(s) | 767 Guest(s)
