37-630 Intermittent issue - solved
(12-23-2016, 11:56 AM)morzh Wrote:  What worries me about the silicone that is sold in stores, it really reeks of vinegar and from what i read it is for a reason - it does either exude acetic acid when curing or something to that effect.
Acid could damage wires.
Maybe it's an empty scare but I do not like acid smell near copper wiring.
It isn't an empty scare.
DO NOT use silicone on electronics. Period. End of story.
I know someone who repairs marine transceivers and related equipment for a living. He once described to me the results of potting a box full of copper wiring with silicone. He received a repair call because whatever was connected to the box stopped working. He opened the box and found that the silicone ate the copper. That's right - very little copper left.
After he told me that, I have refused to use silicone on any electronic item since.
I hadn't heard that. My bad. Icon_redface  Thanks Ron.
Tim
I took Ron's advice and bought some clear epoxy at Lowe's this morning. I just put it on the SM and now have to wait for it to set.
TV: Yes, intermittent problems can be a pain, which is probably why I waited 6 months to get the ambition to chase this one down.
Thanks for the suggestion KC. That looks like it might have worked fine as well.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 978 online users. [Complete List]
» 2 Member(s) | 976 Guest(s)
