My 1942 Philco 42-380X Radio project
I am sorry that i posted here. I thought that some originality would have been appreciated here. I guess not.
I wanted my personality + the radio as the memento. not some old radio that i would never use and thought that the original finish was ugly.
the screen was 149.99$ shipped to my door. i could not get half of the radio restored or parts for it for that cost. you are crazy and wrong.
You guys should really open up your minds and get creative. Originally should be appreciated instead of semi-flamed.
So...what did you do with the original 42-380 chassis and speaker Icon_confused:
You could have restored the original electronics of that radio for less then the cost of that flat screen and the other computer parts, and the set would have been worth more monetarily and historically. If you wanted a memento to your grandparents why deface a perfectly good radio by fitting a PC inside it's cabinet that will be worthless junk in under five years? I can only hope that the cabinet hasn't been hacked up or so full of holes that if you can put it back the way it was someday, assuming of course that you didn't toss out the original parts already.
Arran Wrote:You could have restored the original electronics of that radio for less then the cost of that flat screen and the other computer parts, and the set would have been worth more monetarily and historically. If you wanted a memento to your grandparents why deface a perfectly good radio by fitting a PC inside it's cabinet that will be worthless junk in under five years? I can only hope that the cabinet hasn't been hacked up or so full of holes that if you can put it back the way it was someday, assuming of course that you didn't toss out the original parts already.
and if you actually read my post and the other site's listing, you would see that i already owned the computer. try reading before answering noob. And yes there were a few holes drilled into this radio so that things could be mounted. my children will appreciate a computer, not some crappy old AM radio that some day soon wont even work.
All right, let's calm down and think rationally...
Cerver, you obviously went to a lot of trouble to convert your grandparents' 42-380 into a computer. And I am sure you are proud of your accomplishment. After all, it is yours and you certainly have the right to do with it what you will.
But to call Arran a "noob" because he feels you should have preserved the radio is way out of line, pal.
Arran happens to be a very knowledgeable vintage radio collector and is hardly a "noob."
This is a vintage radio forum, not a computer forum. Please try to keep this in mind. Thank you.
P.S. So what did you do with that "crappy old AM radio" chassis and speaker? I hope you did not just throw it away. Someone could have used it for parts...
Cerver, I just noticed your edit to your original post.
(sound of gavel hitting desk) That's it. You're outta here, pal. Take a walk...
Thread locked. That's all, folks.
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1178 online users. [Complete List]
» 2 Member(s) | 1176 Guest(s)
