Model 801 conversion to AC question
New here. I recently learned Philco in 1942 modified the model 801 car radio into a home model inserted in a end table with 115 vAC renamed the 801-A. I am curious how this AC conversion was manifested.
Welcome to the Phorum!
Icon_wave
I moved your post down into the regular thread section.
Here's the schematic for the AC version from Nostalgiaair.  http://www.nostalgiaair.org/pagesbymodel...013909.pdf
Hi and welcome,
Well the in a nut shell version is that they remover the vibrator and power transformer. PT got replaced w/one w/a 120 primary (old one had a 6v @ 100cy). Looks like most everything is the same between the two chassis. Believe the car chassis is a C-1908 and the chairside is a A-801
 I believe that they converted these pretty much as Terry suggested, even leaving the original rectifier and filter cap can. I've never owned one, though I would like to at some point, but from the photos I have seen they didn't have enough room on the chassis of the MoPar 801 to bolt an AC power transformer so they screwed a vertically mounted transformer inside the cabinet and extended the leads to connect to the car radio chassis. I believe that in the consoles that used a Ford car radio chassis they did have enough space to mount an AC power transformer on the chassis, or at least on the outside of it.
(12-23-2016, 06:45 PM)RAH1915 Wrote:  New here. I recently learned Philco in 1942 modified the model 801 car radio into a home model inserted in a end table with 115 vAC renamed the 801-A. I am curious how this AC conversion was manifested.
Thank you Guys, I was not certain where the question would fit as it was originally a car radio but ended up as a piece of furniture or a home radio. I am familiar with Nostalgia web site but apparently missed that one. Thanks again and have a wonderful Holiday and New Year.
Welcome. Here is a thread from ARF that might help you.
http://antiqueradios.com/forums/viewtopi...6&t=178029
What kind of meter is it? Relative to what is the voltage being measured? Are the AC line filter caps C53A/B hooked up...morzh — 10:47 AM
Hi, what I'm seeing on the schematic is one wire from the output transformer goes to B+ and the other goes to the 7B5 pl...RodB — 10:42 AM
schematics
The Philco Library is great for Philcos.  Great source of info. Philco Libraryslford310 — 09:59 AM
schematics
Hello MSENO, Welcome to the Philco forum and here is the schematic for that Philco! 41-290 Sincerely Richardradiorich — 09:48 AM
I double checked everything around the filter caps and it all seems to be hooked up right... Here are the voltage on ...sq65 — 09:45 AM
schematics
I'm looking for a readable schematic for a 41 290. can anyone help?mseno — 09:33 AM
Rogers Majestic R-646
Since the original schematic was in an old unreadable style, I created a new schematic diagram. Owners of this radio ca...Vlad95 — 11:09 PM
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
There are currently 1480 online users. [Complete List]
» 1 Member(s) | 1479 Guest(s)
