Speaker from model 20 into a model 70?
I am thinking of picking up a model 70 cathedral...The speaker is not original...I have a model 20 consolette that is in very rough shape and has been painted white...was wondering if the speaker out of the model 20 would fit the model 70? They look the same and may have a different output x-former but if the field coils are the same would it work?
Yes....and this link should be helpful in explaining how:
http://philcoradio.com/phorum/showthread.php?tid=14991
Thats EXACTLY what I have been trying to find!! Thanks so much!!
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1040 online users. [Complete List]
» 1 Member(s) | 1039 Guest(s)
