Philci 38-7CS modified with turntable
I picked up this Philco 38-7CS last weekend.
[Image: http://farm3.static.flickr.com/2577/4120...0cf5aa.jpg] [Image: http://farm3.static.flickr.com/2753/4125...794195.jpg]
I was really happy until I did some research and found this thread: <!-- m --><a class="postlink" href="http://www.antiqueradios.com/forums/viewtopic.php?t=78078&highlight=&sid=77cf3359154fb2fda58dee6d350ec8e3">http://www.antiqueradios.com/forums/vie ... 6d350ec8e3</a><!-- m -->
It turns out mine's been modified - That record player and those switches shouldn't be there at all Icon_evil
[Image: http://farm3.static.flickr.com/2699/4134...dae52d.jpg] [Image: http://farm3.static.flickr.com/2802/4134...7cc88b.jpg]
I'm guessing from this service tag I found inside that the mod was done long ago by them.
[Image: http://farm3.static.flickr.com/2742/4125...22a4da.jpg]
The chassis and tuning mechanism are in good shape. Just one metal capacitor missing and a broken volume control shaft.
[Image: http://farm3.static.flickr.com/2706/4135...7853_b.jpg]
I've already decided to restore the wiring to it's original state, but what about the turntable?
If I remove it there will be two large holes to patch and some smaller ones from switches and the tonearm. I do have some suitable walnet veneer and toner lacquer on hand.
[Image: http://farm3.static.flickr.com/2514/4135...3bb277.jpg] [Image: http://farm3.static.flickr.com/2591/4134...4b9090.jpg]
It's a fairly uncommon set (7,750 made) so I'm leaning towards a full restoration of the cabinet right now. I know it won't be easy though.
What do you guys think ?
Bob
Saw your post on this subject over on the Alternative Radio Forum.
Someone went to a lot of trouble to convert that set to use the turntable; not only cutting holes in the base, but cutting a wide groove in the side to accommodate the turntable platter.
If it were mine, I would re-veneer that side and base to restore the original look, and leave the turntable off.
Otherwise...nice find! Icon_smile
I wasn't sure whether to post here or the ARF so I went with both Icon_wink
The general consensus is to remove the turntable and re-veneer so that's what I'll attempt to do Icon_biggrin
Do you happen to have the original toner color scheme for this set?
I'm guessing medium walnut overall, but am not sure if that inset "L" on top should be darker or lighter.
I also picked up these two sets from the same place. Both seem to have been stripped down to the bare wood and given a clear coat. All the character is gone Icon_sad
[Image: http://farm3.static.flickr.com/2181/4121...84db21.jpg] [Image: http://farm3.static.flickr.com/2793/4121...61cd19.jpg]
Bob
Philco Furniture History does not give the color scheme, but from the 38-7CS models I have seen and from your photographs, it sure looks like Medium Walnut to me.
The entire set should be this color - even the contrasting veneer on top. Just the different grain pattern of the veneer inlay (the "L" you refer to) will give it a different look from the rest...which was the intent of the manufacturer.
Looks like you did very well indeed! A 38-7CS, a 70 highboy...and what is that other set, a Jackson-Bell?
Edit: Let's hope that 70 lowboy was not coated in polyurethane. If you can get that clear coat off easily, some Medium Walnut will make it look like new again.
That's what I was hoping to hear - no need to get out the masking tape Icon_smile
The other set is a Sparton 400 (aka Sparton Junior/Jewel).
I have not tested the finish on the 70 yet, but I sure hope it's not poly. too. Otherwise, that cabinet is in really good shape.
Should a Model 70 be all one color ? I thought maybe the face would be a lighter shade than the rest. I've been looking for a good picture of one with it's original finish, but haven't had any luck.
Bob
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
There are currently 1035 online users. [Complete List]
» 3 Member(s) | 1032 Guest(s)
