Threads: 54
City: Lexington, KY
That cabinet has very good photo finish. Those black dial Zeniths are pretty desirable and the three knobs are worth about $60 (if they are the wooden Z knobs). The chassis is a bit rough, but if I had to make an offer it'd be between $75 - $125.
To clean the dial start I'd start with plain water and a soft cotton or microfiber cloth and then a mild dish washing mix if needed, from there you can try other stuff if needed. As with any dial, start in an inconspicuous spot to make sure it will be safe.
Good luck, those are pretty neat radios. My first radio was a similar 5-S-127 that I was given as a teenager and still have it in my collection.
(This post was last modified: 12-19-2016, 11:43 AM by Eliot Ness.)
Threads: 268
Sometimes it will evaporate and go away on it own after a few days.
Threads: 140
City: Lansdale
State, Province, Country: PA
Ok, Parts came in.. The replacement belt for the tuning was installed and working perfect.. Now on the the Capacitor Replacement..
Need to still clean the dial..
[Image: http://i292.photobucket.com/albums/mm38/...0nphbv.jpg]
The spots didn't evaporate..
Skip...
Threads: 268
(12-29-2016, 08:47 PM)vecher Wrote: Ok, Parts came in.. The replacement belt for the tuning was installed and working perfect.. Now on the the Capacitor Replacement..
Skip...
Back to post 16.
Threads: 310
City: Kings Park NY
It looks like when you hit it with splatter from a WD-40 can...
It will take more than water to get off... USe some Gojo very lightly on a tissue. I have never seen it take off dial color or numbers.. Except for philco's,
AC: 4 DC: 1
Threads: 140
City: Lansdale
Ok, All Just finished up the Cap and Resistor replacement. Brought up slowly and at 115 Volts Draw was .5 Amps.. Its alive!!! Received stations on all bands with only a 2 foot antenna.
Now on to cosmetics since I now know it will work great..
Then on to alignment..
Stay Tuned Same Bat time same Bat channel..
Skip...
Threads: 270
City: Wilsonville
State, Province, Country: OR
Threads: 310
City: Kings Park NY
Wonderful!
AC: 4 DC: 1
Threads: 140
City: Lansdale
Ok, Noticed when I started alignment that at low end of the bands when moving the tuning I would hear all kinds of noises. scratching sounds.. When I get to about 600 on AM band noise and scratching goes away. I decided to remove the Tuning Capacitor/. I measured the Cap and one side was OK other was shorted until I got a little way up then all was fine..
See Cap...
[Image: http://i292.photobucket.com/albums/mm38/...9buk7w.jpg]
Question is ... How do you clean this? I thought I would try cleaning in case that's all it is .. Something is shorting.. I looked under a Magnifier and saw nothing that looked like it was touching..
Thanks
Skip...
Threads: 270
City: Wilsonville
I have dunked the entire tuning cap in Metal Rescue for a few hours, a derusting formulation, that cleaned of the rust on my model 50. I have read some have put them in the dishwasher and others in a sonic bath.
Threads: 103
City: Calgary, AB, CA
I have just sprayed it with a good degreaser and used a toothbrush.
Then sprayed down with water to rinse off the degreaser. I used a hair dryer to dry it. let it sit for a day and then lubricate the bearings and gears.
It has always worked for me ..
Dan in Calgary
Living in Calgary Alberta
Threads: 554
City: Jackson, NJ
I guess short of sliding some insulating film you can't really.
Threads: 240
City: West Bend, Wisconsin
I love my ultra sonic cleaner from Harbor Freight for cleaning tuning capacitors. I fill the tank with 3 cups of water and one cup of Simple Green. Does a great job cleaning...and the tuning cap comes out smelling good too!
http://www.harborfreight.com/25-liter-ul...63256.html
Threads: 554
City: Jackson, NJ
Except it won't cure a bent vane.
Threads: 240
True....but it does get the pesky rust dots and other debris out from between fins that cause scratching when tuning.
Here's one source for your wire of many.
Take care and BE HEALTHY! GaryGarySP — 06:40 PM |
...and modern wire of the appropriate gauges and insulation V-rating (300V minimum, usually shown right on the wire) is ...morzh — 05:47 PM |
I have a question about this radio, is there anyone that has access to this radio that has an intact unmolested speaker ...captainclock1988 — 04:28 PM |
Well what makes me confuse all of those companies is that all three of those companies (Setchell-Carlson, Stromberg-Carl...captainclock1988 — 04:21 PM |
The red wire is rubber covered wire.
The others are cotton braid over rubber often in colors or a tracer, also strand...Chas — 02:43 PM |
Greetings Phorum members,
Hope you can help me identify this type of wire in the photo I have attached. I am not sure ...georgetownjohn — 01:53 PM |
Philco 60 Squealing
All correct shields must be in place, all tubes correct no subs of any kind.
Check any soldered, riveted ground conne...Chas — 01:24 PM |
Philco 60 Squealing
I have recapped and replaced out of tolerance resistors and so on. Radio plays nicely on fairly strong stations. The pro...dconant — 10:55 AM |
Welcome Eric,
I agree with Bob and far as the two main electrolytic filter capacitors did you change them yourself or w...radiorich — 11:43 PM |
You mentioned the Philco manual and going through the check points...just to be sure we're on the same page here's the m...klondike98 — 08:13 PM |
There are currently 4322 online users. [Complete List] » 2 Member(s) | 4320 Guest(s)
