Threads: 273
City: Wilsonville
State, Province, Country: OR
I won't be able to get to working on this 91 that I found ( see December Phinds ) until later in the spring but I had to get the chassis out of the cabinet and take a look at it. The topside is very dusty but the good news is there is only some surface rust, no sign of any critters making their home there!!
[Image: https://www.dropbox.com/s/66nmwlzn5el2s1....jpg?raw=1]
The underside is very clean and it does not look like anyone has done any repairs on it either!
[Image: https://www.dropbox.com/s/raxg9yqquum3a4....jpg?raw=1]
The speaker is in decent shape with only a couple small tears that I should be able to fix relatively easily. I'm looking forward to working on this one!!
[Image: https://www.dropbox.com/s/0iq7rjyg6q7hd6....jpg?raw=1]
Threads: 337
City: lawrenceville nj
looks like a nice easy one bob
are you going to re stuff brass cans
sam
Threads: 573
E-Z !!!
Threads: 273
City: Wilsonville
Yes the I'll stuff those mershon cans. Don't ya just love all that chassis space to work in! Its a heavy one though...
Threads: 573
Not any heavier than the 90.
yes. 70, 90, 20 - TONS of space.
118 - not so much.
Threads: 268
With a flaming hot soldering iron in one hand and a large spool of 38ga magnet wire in the other there's nothing Bob can't fix!!!!!
Have at it and have fun!
(This post was last modified: 01-11-2017, 12:55 AM by Radioroslyn.)
Threads: 273
City: Wilsonville
(01-11-2017, 12:55 AM)Radioroslyn Wrote: With a flaming hot soldering iron in one hand and a large spool of 38ga magnet wire in the other there's nothing Bob can't fix!!!!!
 thanks for the vote of confidence Terry !! ....but I also need JB Weld ....
Threads: 573
Make sure you use appropriately powerful butane torch for soldering that wire.
...don't give Kirk any ideas...
Threads: 573
Oh I couldn't possibly even if I wanted to, he's got them all and then some.  My fantasy does not come close to his reality.
Threads: 273
City: Wilsonville
The speaker patching went well. After looking at the photo I may have to make one more patch but I didn't notice it when taking the photo.
[Image: https://www.dropbox.com/s/xxjorisq1sdusy....jpg?raw=1]
This radio has a run number on it, at least I think that's what this is. Looking closely at the stamp it appears it says Philco Radio on top and LAB. on the bottom.
[Image: https://www.dropbox.com/s/c47h8yhlc5lvw0....jpg?raw=1]
You can see the surface rusting on the chassis in the above photo. I'm not sure what I'm going to do about that yet....
I started cleaning the dirt off the chassis with a brush and vacuum and then gave it a light GOJO on paper towel wipe down. Its going to clean up pretty well I think.
[Image: https://www.dropbox.com/s/se9meld4qp86n1....jpg?raw=1]
Threads: 214
City: Seattle
State, Province, Country: WA
Already starting to look nice Bob!
What did you use to patch the speaker?
Threads: 273
City: Wilsonville
Thxs! I used the coffee filter with diluted elmers glue technique that I used on the 60MB earlier. SEE: http://philcoradio.com/phorum/showthread...2#pid85802
Threads: 273
City: Wilsonville
Got a little further along today by checking all the transformers and coils. I thought I was in deep doo doo when the primary on the power transformer showed open but quickly found that the ON-OFF switch was bad. Bypassed that switch and all was good as were all the other coils & transformers!!!
As I mentioned earlier, there are no added caps or resistors to the set.
I'm wondering if perhaps the ON-OFF switch went bad and the owners just put the radio aside to fix later and just never got it fixed.....perhaps to let it wait around for 84 years for me  . There are some non-Philco tubes so there was at least some level of service but there are also still several globe Philco tubes in the set.
The ON-OFF switch is a mechanical lever device that toggles one of those old toggle switches. I don't think you can open those up for repair...has anyone ever fixed one? Here's a pic of it out of the set.
[Image: https://www.dropbox.com/s/c3khg6c038jp59....jpg?raw=1]
Bob
Is that just a single SPST switch?
I've seen a contraption on Phico model 15 sets that two of those switches mounted in such a fashion that you can turn the knob to three positions - OFF, ON LOCAL, and ON DISTANCE. Never seen one on a 91 before, however.
I suspect yours is a replacement, since it appears to only have one switch (off-on). I think all AM-only model 91 sets had a rotary switch like that used in the 50, 51, 52, 70 and 90. as well as many older Phico models.
The mica save was inspired/encouraged by this gem I found:
I'd wondered if it could be done, and for this style of...EdHolland — 12:16 PM |
AES type of Battery Eliminator has hum in B+
The power supply was on Phil's Old Radios web site I did add a isolation transformer. DavidDavid — 11:32 AM |
Something to look at have one and like it. David David — 11:29 AM |
Well, I like to keep it simple and didn't want to mess with perf board. Plus, the owner of this radio is a relative of a...RodB — 10:58 AM |
Rod
Yes, your standard TO-220 LDO is good for 0.7 - 1.5W dissipation (more with a heatsink) and a small current wit...morzh — 10:11 AM |
Mike, I did find an LDO to give me the 90 volts and I got real excited when I discovered it but then I discovered it's ...RodB — 09:57 AM |
These thoughts are are all quite interesting. I wanted to mention that I haven't tried the C- + supply yet. I am new t...Bruce B — 09:45 AM |
Thank you very much, Arran. This is extremely useful information for me.RadioSvit — 07:54 AM |
Peter;
I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM |
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM |
