Philco 39-6
It's been a while since I've been here.  I'm still having OCD issues with my 39-6.  The previous owner replaced the needle/pointer with the wrong type.  In short, this pointer is supposed to have two needles 180 degrees from each other, this one has only one needle.
Does anyone sell parts for this, or a reproduction?  I've been through the forum with the parts vendors, but no one I saw has tuner needles.
No one reproduces the 39-6 dial pointer. You'll have to find one from a junk set. A 39-6, 39-7 or 39-8 will do.
Just as a aside you may want to mount a thin piece the clear plastic (like from a baked good come in) to protect the gold foil on the dial face. If the dial pointer rubs the foil it tears from it's paper backing and can make a mess of the dial graphs.
Thanks for the suggestions - especially about the foil.  I'll keep a lookout.
Hello again;   I found a model 838 car radio on Nostalgia Air under United American Bosch, http://www.nostalgiaair.org/...Arran — 09:32 PM
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
There are currently 5490 online users. [Complete List]
» 2 Member(s) | 5488 Guest(s)
