610 alignment
This can't be correct.  The alignment instructions on Nostalgia air say to hook the output meter up to the plate and cathode of the 42 tube for alignment.   Since the cathode is grounded this just reads the plate voltage.  So do I hook it up between the plate and grid (pins two and three of the 42 tube)?
Keith
It is correct. You do want plate voltage to Chassis/cathode. You should use AC setting for that, you are not interested in the DC.
Got it! The last radio I aligned I was measuring avc voltage so I had the meter on DC.
Keith
It doesn't matter, you could put the leads at the output transformer secondary, across the voice coil, also on AC, or measure DC on AVC voltage. They are all good indicators.
Shadow Meter Bulb
Gary I doubt it would introduce any noise. We use similar lamps for the panel indication, 12V AC lamps: they are LEDs...morzh — 02:15 PM
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
There are currently 8399 online users. [Complete List]
» 1 Member(s) | 8398 Guest(s)
