Threads: 140
City: Lansdale
State, Province, Country: PA
Not sure where this should go.. Please move if its not in the right place
Question about a 50L6 tube.. I have 5 tubes that all check bad for shorts.. Is this normal ? Does this tube have high leakage? I cannot seem to believe all the tubes are shorted.. Or is this a common problem...
Thanks
Skip..
Threads: 553
City: Jackson, NJ
I forgot but in one of Kirk's radios where I had a 42 tube in the output I had the 42 that had a filament short (and was working). I bought another one and it was shorted too. And then another (the short disappeared after a while....????) Eventually I got one that was not shorted.
I do not think it could be normal for a tube to show a short. Even if it works (which is quite possible depending on the arrangement).
Threads: 78
City: Annapolis, IL
Maybe your tube tester? What tester(s) do you have? My Hickok did something weird like that on a 6SN7GT recently, even with the tube out of the socket... haven't gotten into it yet..
Tim
Threads: 553
City: Jackson, NJ
Possible....though a similar suggestion was expressed to me back then and no, it was not the tester.
Threads: 140
City: Lansdale
Ok I used a Hickok 600A tester and a Heathkit IT-17.. All showed short on 5 tubes.. Doesn't seem right. But maybe all 5 are bad? I wouldn't think so But who knows..
Going to see if I have any 25L6 or similar to see what they read..
Skip..
Threads: 553
City: Jackson, NJ
I think all 5 are bad.
This said, you might be able to use some of them in some circuits. It depends on how they are powered.
Threads: 140
City: Lansdale
Ok plugged one of the tubes into radio the Zenith 5D011. All is well plays good with load and clear volume... No excessive current draw 117 Volts at .25 amps...
Thanks
all for the help..
Skip...
Threads: 270
City: Wilsonville
State, Province, Country: OR
I'm curious. If there is a short in the tube, does that mean that there is an unwanted connection between elements inside the tube? For example, between a grid and the plate. If so, shouldn't you be able to detect a short by putting your ohm meter across the various pin combinations? Or is there something else that can cause tube shorts?
Threads: 140
City: Lansdale
I tried that. The tube I am using I checked for shorts pin to pin Tube cold. No shorts.. But when put in Tester showed short I think between Cathode and Filament according to the chart with my Hickok 600A..
Tube works in radio No problems..
Skip...
Threads: 553
City: Jackson, NJ
The short is mostly between the filament and the cathode, and this could be benign in some arrangements. In some others you might have hum. If it works, you are fine.
Threads: 367
City: Dover, OH
It can be amazing how you sometimes find faulty tubes in groups. Usually that doesn't happen, so it can throw one off when it occurs and it can be easy to blame the tube checker. One reason why my friend always said to keep a couple testers around. I have had a similar issue with type 47 tubes lately. I've managed to get three radios with push-pull 47s now and in all three cases one 47 in each radio was burnt out or would burn out as I was testing it. Tapping the tubes lightly would cause an arc inside them, but nothing else. I actually watched one burn the filament out on my tester when I tested the tubes in my Philco 90X.
Threads: 11
City: Bellmawr, NJ
THAT is what ,,I was show,,was to flick your finger against the tube ,,in tester,,while pushing the test button,,for any kind of short,,be-side the short test,,,CHEERS
Threads: 25
City: Wellborn Florida
50l6, 50C5, 35W4, 35Z5, If working on a All American set (AC DC) that has a bad tube good chance one of the following. David
Threads: 412
City: Boston
Outputs and rectifiers often are candidates to go, if they were pulls maybe they are all bad, really.
Threads: 40
City: Lehighton
I have 7 50L6GT here and none test as a short.
Tim,
nice write up and thanks for sharing !!
Sincerely Richardradiorich — 02:47 AM |
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM |
Shadow Meter Bulb
Phorum members, I am trying to find the bulb # for PHILCO Shadow Meter part number 45-2180 that is from a 37-640 chassis...georgetownjohn — 06:53 PM |
Philco 41-608 changer coupler
3D-printing...short of machining, of course.
Or molding.morzh — 05:20 PM |
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal piec...alangard — 05:07 PM |
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM |
12' Philco
Rod,
Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently.
H...morzh — 12:54 PM |
There are currently 6188 online users. [Complete List] » 2 Member(s) | 6186 Guest(s)
