Aerial Label
Does anyone know what the original color combo was on this 37-610 Aerial label? I'm trying to create a new label using this old one as a guide.
I'm assuming it was black and white and like every thing else has turned brown with age, but I wanted to make sure. Thanks in advance.
Kelly
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
That label is printed in a dark navy blue. I previously created a repro of it here:
http://philcoradio.com/phorum/showthread.php?tid=13296
In many photos the label has darkened and almost looks black. The original color shows up a bit better in this photo (compare to the black tube bases).
https://drive.google.com/open?id=0B64cfW...083UFZiZ2s
Thanks Nathan.
Good job by the way.
Kelly
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
There are currently 1291 online users. [Complete List]
» 1 Member(s) | 1290 Guest(s)
