My Mershon disassembley method
Would like to share this method I tried with success.
First part I read on another thread to remove the cap worked great.
To remove the caps, I froze the can for a few days.
Then I immersed the top cap in boiling water.  Used a pair of rubber gloves wrapped around the cap with a set of channel locks for a grip.
GENTLY twist them off. They came off very easy.
Next, I thought of a neat way to get at the insides.
Invert the can on a stationary belt sander and sand lightly.
Took less than 2 minutes.
No digging, drilling, cutting etc.
You can even solder the piece you removed back in there some how if you really want to be cool.   Icon_e_geek
Thanks!
Icon_thumbup
Glad to be of some help.
There are people on here that seem to know everything about these antique radios.
Hope my little 2 cents helps.
Great idea Icon_thumbup  Thanks for sharing.
Neat!
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
