Is using ammonia to clean coils really a good idea ?
I have read throughout forums that using ammonia to clean coils to neutralize the acid from the plastic breaking down is a good idea before rewinding.
However I have also read that ammonia removes varnish, which is what the wire is coated with.
I can attest that ammonia will indeed remove varnish from coils.
So the big questions are is the ammonia to be diluted, what ratio, and how long of an application ?
OR is there a better alternative to remove the risk from eating the varnish away and still neutralizing the acidic surface ?
Also while we are on this subject, on Philco 70, 90 the primary is 32 awg.
Has anyone rewound the secondary and what gage did you use ? Were you successful ?
Don't do it, ammonia reacts with copper in a very negative way, same with brass, not quite like an acid but it can make it brittle. I would use something like baking soda or washing soda to neutralize acid if you are worried about it, at least it won't damage the copper.
This is a link that references ammonia.  I think I will stick with baking soda.
http://www.philcorepairbench.com/tips/svctip36.htm
In my lab I sometimes use regular soap to neutralize after acid treatment. Really anything alkaline should work.
There are currently 1885 online users. [Complete List]
» 2 Member(s) | 1883 Guest(s)
