Philco 60 Oscillator with a Weird Problem
Or when you "cleaned" the coil did it remove the insulating coat of lacquer from the winding under the feedback winding?  Did you see bare copper?
(05-16-2017, 01:06 PM)morzh Wrote:  The impedance of 38 gauge will not do that. It is low no matter what.
Could it be you wound it in opposite direction? Have you tried swapping the ends?
I recalled some spots of green oxidation. Well, that's the same as bare copper. I better have the boss order some of that gauge of wire then.
Yes, I reversed the wire and it made no difference.
Oxidation is no good either. Is the continuity still there? At any event, if you see oxidation, it has to come out and be replaced.
And the bobbin has to be baked. And if there is still celluloid film left, has to come out too - this is what causes oxidation.
All the celluloid was removed and the windings underneath were treated with a solution of ammonia and water after I scrubbed off the corrosion. Could be the winding underneath was compromised and shorted.
Ammonia on copper, always a bad idea.
M R Radios   C M Tubes
If you see corrosion, remove the winding and redo.
Wow, it's been nearly a year since I posted this and I didn't give a conclusion. I apologize. Thanks to morhz and Steve I revisited this coil late last year and removed the secondary and corroded primary and rewound them. I installed this coil in another 60 that I cannabalized earlier and it now works. The second time around went much quicker. Thanks.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
