Terry answered it all.
#4 says "without the rectifier". The rectifier IS the 80 tube so it means, without it.
Also in #1 you tested everything, field coil and the output xfmr primary, so all is good. The output secondary always shows as zero (zero means short, not opsn) and it is OK.
Threads: 24
City: Orland Park
State, Province, Country: Illiinois
This is perfect, now I get it. I'll be back this week with the results of the other tests. Thanks again, guys.
Greg
Threads: 24
City: Orland Park
Update:
The filament continuity test was easy enough, so I did that and everything seemed to pass. However, my replacement bulb for my tester came today and I decided to test everything following the booklet instructions: one of my 24s failed the cathode short test. Of course it had to be the really cool, old Philco branded globe style which is probably original. Additionally, my 27 tube technically passed, but in the final test, the needle was in the "?" area, so guessing that one is iffy.
I know I at least have a bad 24, so I'll need one of those.
Greg
? Area still works, just get the 24A.
Threads: 24
City: Orland Park
Ok
Greg
Threads: 24
City: Orland Park
I'm finally back after getting sidetracked by work and vacation.The new tube came, so I figured I'd run these tests; results are below:
80 filament voltage: 5.4v
71A filament voltages: 5.5v
27 filament voltage: 2.7v
24 filament voltages: 2.7v
These above look more or less ok from the charts.
Plate voltage test for 80 (#6 from list): I got 364 at pin 2 and 366 at pin 3. (I think I may have done this test wrong, I'm thinking I was supposed to probe pins 2 and 3 together like in the filament voltage test rather than place - probe to chassis and + probe to pin 2 or 3... if so let me know and I'll re-do)
The B+ test at tube 80 (#7 from the list) gave me 272v.
Plate voltages (#8)
27: 101 (chart says should be 120)
24: 215, 215, and 95 (chart says they should be 250, 250 and 35)
71A: 203 and 217 (chart says they should be 215)
Any thoughts?
Greg
Threads: 270
Measure the dc voltage from pin 3 of each of the 71's to the chassis. Should see some -voltage there on both unless the interstage transformers secondary is open.
Now I think I've got it!
Threads: 24
City: Orland Park
Ok, will do that tonight!
Greg
Threads: 24
City: Orland Park
Ok, one reads -8.7 the other reads +0.7 and when I touch the probe to it, the speaker crackles and the hum gets louder.
Greg
Threads: 270
Seems like 1/2 of your interstage transformer is open. This is why the plate voltage on your 71's isn't more even, one tube has no grid bias and it's causing the plate to draw more current. Just to confirm measure the resistance from each 71 grid back to the center tap of the transformer. Should see a fairly low resistance 1K or less.
(This post was last modified: 06-19-2017, 10:18 PM by Radioroslyn.)
Threads: 24
City: Orland Park
That makes sense as I've read on other threads those are problematic on this model. By "grid" you mean pin 3 again, right? I'll check resistance tonight. Thanks again, Terry.
Greg
(This post was last modified: 06-20-2017, 11:52 AM by WallaceRoger.)
Threads: 270
Yup
Threads: 24
City: Orland Park
Ok, one of them is 3k, the other is 7.2M. That sounds like a problem : ) The center tap is the wire that connects to point 1 on the filter can, right?
Greg
Threads: 270
Threads: 24
City: Orland Park
Ok, thanks Terry.
Greg
There are currently 1791 online users. [Complete List] » 2 Member(s) | 1789 Guest(s)
