Philco 118 Bakelite Capacitors
I am working on a Philco 118 which has 11 Philco bakelite capacitors in it. The bakelite capacitor information in the past was in the Philco Repair Bench. Is that information still available and if so, where do I go to find the numbers and capacitor connections for the bakelite capacitors?
Thank you,
Best Wishes,
Oscar
nv3g
Don't worry the internet is forever Icon_smile
https://web.archive.org/web/201603242301...rtinfo.htm
I believe that info will return to the current site - it is just undergoing renovations at the moment. See this thread: http://philcoradio.com/phorum/showthread.php?tid=16781
Just about anything you need to know about a Philco radio can be found right here on the Phorum.
Look here.  http://philcoradio.com/phorum/showthread.php?tid=14964   and here    http://philcoradio.com/phorum/showthread.php?tid=9107
M R Radios   C M Tubes
There's a website that lists all of the bakelite condensers by part number with related contents and values... I can't find it currently but have it saved to my favorites at home. I'll post it tonight.
Greg
Oh nevermind, Nathan posted it up above.
Greg
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
There are currently 5027 online users. [Complete List]
» 1 Member(s) | 5026 Guest(s)
