philco 42-360 power transformer
I have a Philco 42-360 that needs a new power transformer. The schematic shows 320 vdc on the output of the rectifier 84. I`m not sure what the current requirements are needed to operate this radio.
Welcome to the Phorum!
Icon_wave
Can't answer your question but someone surely will be able to help. The service bulletin for the radio is available at http://www.audiophool.com/Philco.html .
Hi and welcome to the Phorum,
Your looking at about 60ma. They're pushing that 84 pretty hard.
Well....let's try to do the first order calculation.
The rectified voltage is 320V. The dropout across the field coil's DC resistance of 1.7kOhm is 130V (down to 190V). We're lucky we have the numbers directly before and after.
This makes the total of 130V/1700 Ohm = 75mA.
Now each half-winding will conduct the same average current exactly 1/2 of the period that makes it 38mA average per half-winding.
Add a margin of say 50% (or whatever you are comfy with), this will make it 57mA. I'd say, that is enough.
(Almost radio engineer)
PS. Saw Terry's reply. Hey! I was pretty darn close! Icon_lol
Hey Mike,
I do the rough calculation by multiplying the # of tube not counting the OP or rectifier X 5 (ma) If and tube has more than 1 section + 5 more ma per, diodes don't count. OP= 20ma. So 7 tubes X 5ma + 20= 55ma + a little for good luck=60ma.
Then I look up the tube specs to see if the rectifier can handle the current load. 84 is good for 60ma.
I'd do the same, but when I'm lucky to have the Voltages directly shown along the current path, with known resistances for the dropouts, I use those - takes the guesswork out of the process.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 758 online users. [Complete List]
» 1 Member(s) | 757 Guest(s)
