Silvertone 4588 refinish
I was lucky enough to find this 1936 top of the line silvertone 4588 on craiges list. 120 mile round trip got it to shop and started work on cabinet. Love that dial and design of cabinet, 13 tube set plays great after some caps were replaced and dial cord. . Cabinet was solid and just needed a refinish, thought I would share this with you guys.
A few pics of chassis.
Very beautiful and stylish radio. My greetings to its owner
Fred, you are a master!
Crist
Gorgeous radio. Well done!
Greg
Fred, as always, fantastic work!
M R Radios   C M Tubes
Beautiful work! I really like that era of Silvertone radios.
One spiffy-looking set!
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
There are currently 4992 online users. [Complete List]
» 1 Member(s) | 4991 Guest(s)
