Philco 650 Chairside Radio
I just acquired a Philco model 650 Chairside radio. Eight ( 8 ) tubes , original knobs (Yea!) and cabinet intact. I cannot locate ANY data on this radio. I also find the radio interesting as it had no grille cloths ... the outlet grills on all sides were backed by "baffle boards" ca. 1/4 inch from the inside cabinet. Unfortunately, the original speaker(s) were replaced by more moden permanent magnet type speaker.
Any and all information on this interesting radio will be greatly appreciated.
Regards, all,
Frank
Hi
Great acquisition! I had one of those a few years ago...wish I had kept it.
I have some info on the 650RX here:
http://www.philcoradio.com/gallery/1936a.htm#an
I seem to recall that the separate speaker cabinet originally used a permanent magnet speaker, and it used a choke instead of a field coil.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1269 online users. [Complete List]
» 2 Member(s) | 1267 Guest(s)
