Switchable AUX Input
This may be a "yeah so?" thread for the more electronically adept out there, but I figured I'd post my latest work as a reference for others looking to add a switchable AUX input.
For the last couple of years I have been using these instructions to add an AUX jack to my restorations:
http://www.spridgetguru.com/TA0041.html
A 1/8" Radio Shack Jack is installed as per the directions and the AUX audio is fed through the volume pot. Bingo/Presto no problem.
The only "issue" with this set up is that when you plug in the AUX cable it cuts out the AM broadcast (with some bleed through on strong stations) and you have to keep on pulling and inserting the cable to swich from AUX to AM/SW. I am thinking about using a 1/8" Audio Jack Bluetooth receiver but don't want to keep fishing around the back of the radio for the jack. A switch that I could flip for Broadcast/AUX would be much easier. This is how I did it.
I used the same instructions as above minus connecting pins 3+4 and running the wire from there to the cap/resistor/wire I removed from the Top terminal of the volume pot.
[Image: http://i.imgur.com/g0tAfHF.jpg]
I drilled a hole in the chassis back and added a RatShack SPDT 3 pin switch.
[Note: I snipped off those stray strands of wire on the bottom post. Icon_smile ]
[Image: http://i.imgur.com/bKUPdFZ.jpg]
[Image: http://i.imgur.com/rcbxjnC.jpg]
Then I ran the wires as so:
  • From the Top post of the volume vot to the center pole of the switch.
  • From the AUX input jack (the wire connected to the two resistors as per the instructions) to one of the side poles of the switch.
  • From the remaining pole of the switch to the wiring that was originally connected to the TOP post of the volume pot.
P.S.-Black wire is to ground.
[Image: http://i.imgur.com/eer78i1.jpg]
Now I can leave the aux cable permanently attached to a device and switch between Broadcast and MP3 with the switch. I still have to turn the dial off of strong stations to prevent bleed through but I find this solution much more convenient.
Video:
https://www.instagram.com/p/BXyjDDVhBJk/?hl=en
don't want to tell you --hope you see this,,,----about ,,that 1 strand of copper ,,,on bottom terminal,,really close to the middle terminal,,,,cut or re-insert into terminal hole,,,and solder----in #2 picture,,,,SORRY-----CHEERS
Yeah. Snipped already. Too lazy to reshoot. Icon_smile
My Philco 37-116 Restore
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
