Philco 90 toner and grille cloth
Hi,
I'm restoring a Model 90, and using Mohawk toners. Most restorations seem to make the pillers and feet a darker color than the body, I'm using Perfect Brown and Dark Walnut. Can I spray the entire cabinet Perfect Brown and after drying put the Dark Walnut over it?  I know that the Walnut will probably melt the Brown some but will the Walnut lay on top of the Brown OK?
Also, until a couple of years ago you could get good replacement grille cloth even the original copper color, but now there seems to be nothing close. Anybody know of any source?
Alan
Your best bet would be to try the various toners on pieces of scrap and see how they look. that will let you get it to a tone that you like.
Alan
Yes, it is perfectly fine to spray your main body color overall, then spray just the areas needing to be darker with the darker toner, provided you carefully mask off as needed using newspaper and green Frog Tape.
Whatever you do, do not use blue painter's tape. I learned this the hard way a few years ago...it is chronicled here in the Phorum somewhere...
As for cloth, you have two choices: Whiskey Rayon from Kenny Richmond, or GRC02 from Radio Daze.
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1164 online users. [Complete List]
» 2 Member(s) | 1162 Guest(s)
