Philco 91-121 sensitivity
If anyone has a 91-121 or 91/221 ( broadcast only) radio and you want to check, please see if your on/off switch has an extra "on" position (far right) that affects the sensitivity. The schematic and 44RF cathode tube socket data don't make sense as shown, thank you Terry, but 25 volts with the switch off and 5 volts with it on could account for this. The schematic and tube voltage data are here: http://www.nostalgiaair.org/Resources/884/M0013884.htm
Bob
This sounds like either someone adapted the model 15 local-distance circuit to a 91, or else this is yet another of those undocumented factory mods.
Take a look at the model 15 schematic and see if the switching circuit is the same:
http://www.philcoradio.com/images/phorum/schem/15.jpg
The 91 on my bench at the moment has only the ON-OFF function.
Thank you Ron and Bob, that local/distance switch in the 15 schematic matches what I have. Checking the tube socket data for the 15 shows 30 volts on the 44RF cathode (only one listing). Going back to the 91-121, should all of them normally have 25 volts on the 44RF cathode unless they were a factory or "aftermarket" modification?
Bob
Reading Bob's (klondike98) restoration progress on his 91 and Ron's comments about the on/local/distant switches reminded me of another set of questions. My 91-121 with the three position switch has the remnants of the gold Philco sticker on the chassis that models without the one piece tube shield had (the tube shield has the intact one). Also is there any significance in the stamped numbers on the chassis? I have C49313; there is no visible star like run number. Thank you.
Bob
I don't believe the C49313 has any useful meaning.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1095 online users. [Complete List]
» 3 Member(s) | 1092 Guest(s)
