Hello! 38-12 Dial Question
UHello!  I am new to your group and looking forward to your advise.  I have several Philcos and am now retired and looking forward to repairing them.  I am new to radio repair and have limited electronics background.  Up first is my 38-12 (hopefully with pix attached).  I have a new Dial Face on its way and my first question is about the Dial pointer.  I believe this is friction fit but mine is not removing itself easily.  Any advice on how to remove one which is séized without damaging it?
The Dial Face appears to be encased in knurled edges from the face plate.  Do I just insert something to open up the knurled edges so I can insert the new Dial Face?
Any help is much appreciated!
[attachment=14663][attachment=14663]
Hi and welcome!
The dial pointer is indeed held on by friction; it simply presses into place. There is a hole in the shaft and a pin on the back of the pointer presses into this hole.
Careful use of a pocket knife with a long blade may help in removing the pointer from the shaft. If you can carefully work the blade between pointer and shaft, this may allow you to get the pointer out. Do be careful not only to not break the pointer, but to not cut yourself!
Hi and Welcome,
Just as an side you may want to put the piece of clear plastic over your new dial between to it and the pointer so the pointed won't get that one too.
I used my two index fingers to pull the pointer out. Icon_smile
By the hub of course.
Welcome to the Phorum!
Icon_wave
Thanks for your insight! I appreciate your advise. I should get the face this week and will put your methods to use!
The pointer is off without incident! If anyone has any easier way to uncrimp the steel surrounding the old foil Face plate please reach out. I am wedging a thin screwdriver and rocking it but am not pleased with my result. I can't even get a razor blade wedged between the steel and the original face. It must have been pressed into place during its manufacture.
Thanks in advance!
Most of the ones I've seen aren't crimped along the edges but have little snap in fasteners near the corners. Remove 3 or 4 of them and the dial card come off. I would take your new dial place a suitable piece of clear plastic over it then use the two original screws to remount it. Or takev your tin and turn it the other way around. Put the new dial on the backside. Use the original screws to remount w/ a plastic on the front to prevent rash.
[Image: http://northernelectric.ca/radios/philco...t_orig.jpg]
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1118 online users. [Complete List]
» 1 Member(s) | 1117 Guest(s)
