Philco 60 Warped Dial
Is it possible to flatten this warped dial?  Otherwise, Radio Daze has an excellent reproduction.
[Image: https://farm5.staticflickr.com/4232/3505...3c61_n.jpg]
Henry
I had a similar looking dial on my 81. Just popped it off the shaft, laid it on a flat surface, gently used a head gun and a small piece of wood to flatten it.
How did you pop it off of the shaft without breaking the rivets?
Right. The rivets would be a problem, but I can leave the dial on the shaft and make a U-shaped press. If it'll stand up to the minimum heat to make it plastic--that's what I needed to know. If necessary, the rivets can be replaced with small nuts & bolts. Thanks.
<How did you pop it off of the shaft without breaking the rivets?
Let me rephrase, I removed the dial and it's bracket from the tuning capacitor shaft by loosening the set screw.
Let me clarify.  I didn't mean to leave it on the shaft, but to leave the dial riveted to the metal.  I was wary of melting or burning the dial, so I heated, pressed, and cooled three times; increasing the heat each time until it softened adequately.
[Image: https://farm5.staticflickr.com/4313/3512...a48cac.jpg]
It worked. Thanks for the help.
Wow, great tip. Thanks for posting!
To follow up on flattening the warped dial.  Even when I thought I had successfully flattened the dial, it warped again after 24 hours.  For my final attempt, I totally removed the plastic, heated it almost to melting, then kept it clamped flat overnight.  That worked permanently.
But I bought a repro dial, anyway.  Here's the way I removed the old dial and attached the new one:
Cut off the rivet heads from the back of the dial.  Affix the new dial with golf grip tape (thin, double-sided adhesive).  Stick the rivets back in the holes and hold them in with a dab of epoxy putty from the back side.
[Image: https://farm5.staticflickr.com/4314/3600...bcc48e.jpg]
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
There are currently 1042 online users. [Complete List]
» 3 Member(s) | 1039 Guest(s)
