42-380 Restoration Started
Here is the cabinet of a 42-380 I'd like to redo.
It's seems solid enough but the finish is hazing on the sides and the veneer is peeling off the top. I might have it professionally done but I'd appreciate any advice before I get started.
[attachment=1]
[attachment=0]
VENEER IS ALMOST IMPOSSIBLE TO FIX .I WOULD HAVE A PRO TACKLE THIS ONE . Cost a little but you will get a nice job .
I love theses big consoles if i had room i would buy ever one i came across . Icon_biggrin
Denver.
here is a site that will help you http://www.antiqueradio.org Icon_biggrin
Denver.
Thanks for the advice. By chance any idea of a fair ballpark number. I haven't had any experience getting these redone but I would imagine I'm looking at two or three hundred.
At the least . Lot of money but i think these old sets are worth it . Icon_biggrin
Quotes are in:
Cost to repair veneer: $150 to $180.
Cost of complete refinish (not including photofinish repair) $300 to $460.
I'm thinking how hard can the veneer be to repair or replace...
If anyone has tackled re-veneering and has anything they want to share, I'm all ears.
Thanks to encouragement and inspiration Steve DeClario, I'm going to attempt to reveneer, and refinish.
Steve said the top would come off and what-do-you know, it does.
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
There are currently 3840 online users. [Complete List]
» 1 Member(s) | 3839 Guest(s)
