A Philco 91B
I’ve started the cabinet restoration for this 91B.  Its finish is flaky and needs to be redone but the cabinet itself is in pretty good condition.
[Image: https://www.dropbox.com/s/os1fj55yzqk607....jpg?raw=1]
Some of the veneer is beginning to come loose and the back side edge of the front arch has lost some of the veneer so that needs fixing as well.  Some of the larger chips in veneer on the back edge will also get fixed with the smaller ones just getting filled with Timbermate wood filler.
[Image: https://www.dropbox.com/s/uym2044hj5eswh....jpg?raw=1]
[Image: https://www.dropbox.com/s/8cmfka8xqnzu4o....jpg?raw=1]
The base has a crack and the plywood is separating a bit but injecting a little wood glue fixes it easily.
The stripping process is using Citristrip since that works well indoors.  I usually follow-up with wiping the cabinet down with lacquer thinner as well but that’s an outdoor job that will have to wait until warmer weather.
[Image: https://www.dropbox.com/s/ilp395n20bw002....jpg?raw=1]
After finishing the stripping, the cabinet looks 100% better even without toner and clear!  The routed edge around the center inset panel is a much lighter wood than anything else so I’ll have to do some extra toning on that.  Ron describes the various toned cabinets that were made for the 91B in an earlier thread.  Mine was one of the cabinets that had a dark “trim package” so I’ll try to reproduce that in the spring.
[Image: https://www.dropbox.com/s/zdbcd5r89kaedz....jpg?raw=1]
That little edge of the front laminate is always falling off just above the router cut for the arch. I have patched so many of those on Philcos, but the same is true for Crosleys.
It's a common problem with many cathedral, and tombstone cabinets unfortunately, I have a 1931 Rogers cabinet with the same problem. I don't know why they needed that lip along the front edge, they could have finished it off flush, maybe they like the false front look like an old Western town.
Arran Wrote:
Quote:I don't know why they needed that lip along the front edge, they could have finished it off flush
The Philco 20 used a "rabbit cut" on the back edge of the front. They used several tiny nails to hold the wrap in place while the glue dried. Then the edge of the front was then trimmed flush. This left a raw edge of the front that had to be hidden when the cabinet was finished by using dark toner and sometimes shading the edges. Later on Philco (and other manufactures) figured out by cutting a groove, the wrap could be installed in seconds and would leave no raw edges.
M R Radios   C M Tubes
Yep. It is the old hide glue that is the problem.
Finally getting back to the 91B cabinet.  I had it stripped back in Dec 2017 but am just now getting a chance to spray in between the rain drops...
I did a light coat of medium brown walnut ultra classic mohawk over the entire cabinet except the trim and front panel the other day...
[Image: https://www.dropbox.com/s/xgme5gjmhh6vol....jpg?raw=1]
and then did the trim with extra dark walnut ultra classic mohawk  and also with a very light dose of it on the front panel.
[Image: https://www.dropbox.com/s/unwhx0bf67k6ic....jpg?raw=1]
Abt time!!![Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
Looks good!
I just applied some sanding sealer to that 70 frt panel I got @ Ktwn.
Weather as been lousy for lacquer spraying. Too much humidity!
It looks fantastic! Great work.
Gregg Icon_thumbup
A gift from the heavens today...weather warm enough to spray lacquer with low enough breeze and humidity. Was able to put what I hope is the final coat of clear gloss on. Will wait a few weeks to rub it out and then put the chassis back in (which was finished many months ago!).
[Image: https://www.dropbox.com/s/6j1udn1r2ph71n....jpg?raw=1]
Great job! Icon_thumbup Icon_thumbup
To quote Charlie....
[Image: https://www.dropbox.com/s/jkj08kqnbh1bky....jpg?raw=1]
I put the chassis into the cabinet, all the knob shafts slid right into their holes, chassis bolts all lined up and I went to add the escutcheon and.....
[Image: https://www.dropbox.com/s/tqpusndazoghfz....jpg?raw=1]
That gap between the escutcheon and the dial is not supposed to be there.  The shadow meter lines up ok and as I mentioned so do the chassis knobs so it has to be a problem with the dial scale.  Unfortunately the old one was broken and I tossed it so I can not compare it.  The dial mounting holes lined up with the metal piece that it mounts on.  I don't think it is rubber tuner mounts as they are relatively pliable and the tuner knob shaft would be out of place if the tuner was lifted any more.
Jeff had a similar problem with his 66S but that turned out to be a modification that had been made to a larger dial.  There is a later 91 dial that is a 2 band version but my set is only the single broadcast band.
Interestingly, the picture of the 91B in the Phorum gallery shows the dial scale with the number very low in the escutcheon window
I'll pull the chassis out again and ponder on this a bit.... Icon_confused
On a closer look, those rubber tuner grommets are not as pliable as I thought and have crushed down a bit. I went slower (always get impatient as I get to the final steps of putting these together) and actually mounted the escutcheon and found less of a gap than I thought. Replacement of those grommets may just solve this so they are on order.
Looking good!
Icon_smile
I was about to say: the grommets under the tuning cap.
Although I have to say they solved it marginally for me: on the 18 I still have some gap.
Aren't there also rubber grommets under the screws holding chassis to the floor?
There should be, yes. Also: all of the tuning condenser grommets I have seen of this vintage Philco used steel sleeves to prevent the grommets from completely collapsing when the mounting bolts were tightened down.
Yes, Philco had a name for that but the name escapes me at the moment. The dials were designed so that the owner could note their favorite radio stations in the blank spaces above the actual dial markings.
Value of capacitor
What is an OP?  Looks like the “OP” mistakenly typed electrolytic.  Lets forgive him.Joe Rossi — 06:31 PM
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
